Datasheet ADCMP563, ADCMP564 (Analog Devices) - 3
DescriptionDual High Speed ECL Comparators
Pages / Page15 / 3 — Data Sheet. ADCMP563/ADCMP564. SPECIFICATIONS. Table 1. Electrical …
RevisionD
File Format / SizePDF / 291 Kb
Data Sheet. ADCMP563/ADCMP564. SPECIFICATIONS. Table 1. Electrical Characteristics Parameter. Symbol. Conditions. Min. Typ. Max. Unit
Data Sheet ADCMP563/ADCMP564 SPECIFICATIONS Table 1 Electrical Characteristics Parameter Symbol Conditions Min Typ Max Unit
VCC = +5.0 V, VEE = −5.2 V, TA = −40°C to +85°C. Typical values are at TA = +25°C, unless otherwise noted.
Table 1. Electrical Characteristics Parameter Symbol Conditions Min Typ Max Unit
DC INPUT CHARACTERISTICS Input Voltage Range −2.0 3.0 V Input Differential Voltage −5 +5 V Input Offset Voltage VOS VCM = 0 V −10.0 ±2.0 +10.0 mV Input Offset Voltage Channel Matching ±2.0 mV Offset Voltage Temperature Coefficient ∆VOS/dT 2.0 µV/°C Input Bias Current IBC @ −IN = −2 V, +IN = +3 V −10.0 ±3 +10.0 µA Input Bias Current Temperature Coefficient 0.5 nA/°C Input Offset Current ±1.0 µA Input Capacitance CIN 0.75 pF Input Resistance, Differential Mode 750 kΩ Input Resistance, Common Mode 1800 kΩ Active Gain AV 63 dB Common-Mode Rejection Ratio CMRR VCM = −2.0 V to +3.0 V 80 dB Hysteresis RHYS = ∞ ±1.0 mV LATCH ENABLE CHARACTERISTICS Latch Enable Voltage Range −2.0 0 V Latch Enable Differential Input Voltage 0.4 2.0 V Latch Enable Input High Current @ 0.0 V −300 +300 µA Latch Enable Input Low Current @ −2.0 V −300 +300 µA LE Voltage, Open Latch inputs not connected −0.2 0 +0.1 V LE Voltage, Open Latch inputs not connected −2.8 −2.6 −2.4 V Latch Setup Time tS VOD = 250 mV 200 ps Latch Hold Time tH VOD = 250 mV 200 ps Latch to Output Delay tPLOH, VOD = 250 mV 500 ps tPLOL Latch Minimum Pulse Width tPL VOD = 250 mV 500 ps DC OUTPUT CHARACTERISTICS Output Voltage—High Level VOH ECL 50 Ω to −2.0 V −1.15 −0.81 V Output Voltage—Low Level VOL ECL 50 Ω to −2.0 V −1.95 −1.54 V Rise Time tR 10% to 90% 530 ps Fall Time tF 10% to 90% 450 ps AC PERFORMANCE Propagation Delay tPD VOD = 1 V 700 ps VOD = 20 mV 830 ps Propagation Delay Temperature Coefficient ∆tPD /dT VOD = 1 V 0.25 ps/°C Prop Delay Skew—Rising Transition to Falling VOD = 1 V 50 ps Transition Within Device Propagation Delay Skew— VOD = 1 V 50 ps Channel-to-Channel Overdrive Dispersion 20 mV ≤ VOD ≤ 100 mV 75 ps 100 mV ≤ VOD ≤ 1.5 V 75 ps Slew Rate Dispersion 0.4 V/ns ≤ SR ≤ 1.33 V/ns 50 ps Pulse Width Dispersion 750ps ≤ PW ≤ 10 ns 25 ps Duty Cycle Dispersion 33 MHz, 1 V/ns, 0.5 V 10 ps Common-Mode Voltage Dispersion 1 V swing, −1.5 V ≤ VCM ≤ +2.5 V 10 ps Rev. D | Page 3 of 15 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TIMING INFORMATION APPLICATION INFORMATION CLOCK TIMING RECOVERY OPTIMIZING HIGH SPEED PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
