Datasheet ADCMP563, ADCMP564 (Analog Devices) - 8
DescriptionDual High Speed ECL Comparators
Pages / Page15 / 8 — ADCMP563/ADCMP564. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 3.0. …
RevisionD
File Format / SizePDF / 291 Kb
ADCMP563/ADCMP564. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 3.0. 2.80. 2.78. 2.5. 2.76. 2.0. 2.74. 1.5. 2.72. IN = 0V). 1.0. – 2.70. 2.68. 0.5
ADCMP563/ADCMP564 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 3.0 2.80 2.78 2.5 2.76 2.0 2.74 1.5 2.72 IN = 0V) 1.0 – 2.70 2.68 0.5
VCC = 3.3 V, TA = 25°C, unless otherwise noted.
µ
A)
µ
A) 2.74 1.5 2.72 IN = 0V) 1.0 – 2.70 2.68 0.5 (+IN = 3V, 2.66 0 INPUT BIAS CURRENT ( +IN INPUT BIAS CURRENT ( 2.64 –0.5 2.62 –1.0
04650-0-013
2.60
04650-0-016
–2.5 –1.5 –0.5 0.5 1.5 2.5 3.5 –40 –20 0 20 40 60 80 NONINVERTING INPUT VOLTAGE (INVERTING VOLTAGE = 0V) TEMPERATURE (
C)
Figure 8. Input Bias Current vs. Input Voltage Figure 11. Input Bias Current vs. Temperature
2.00 –0.8 1.95 –1.0 1.90 1.85 –1.2 1.80 1.75 –1.4 1.70 –1.6 1.65 OFFSET VOLTAGE (mV) OUTPUT RISE AND FALL (V) 1.60 –1.8 1.55 1.50
04650-0-014
–2.0
04650-0-017
–40 –20 0 20 40 60 80 0 0.25 0.50 0.75 1.00 1.25 1.50 1.75 2.00 TEMPERATURE (
C) TIME (ns)
Figure 9. Input Offset Voltage vs. Temperature Figure 12. Rise and Fall of Outputs vs. Time
550 475 545 470 540 465 535 460 530 455 525 450 TIME (ps) 520 TIME (ps) 445 515 440 510 435 505 430 500
04650-0-015
425
04650-0-018
–40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 –40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 TEMPERATURE (
C) TEMPERATURE (
C)
Figure 10. Rise Time vs. Temperature Figure 13. Fall Time vs. Temperature Rev. D | Page 8 of 15 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TIMING INFORMATION APPLICATION INFORMATION CLOCK TIMING RECOVERY OPTIMIZING HIGH SPEED PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
