Datasheet CMP04 (Analog Devices) - 4
DescriptionQuad Low Power, Precision Comparator
Pages / Page8 / 4 — CMP04–Typical Performance Characteristics. 0.3. 3.0. 0.2. 2.0. 0.1. 1.0. …
RevisionE
File Format / SizePDF / 219 Kb
CMP04–Typical Performance Characteristics. 0.3. 3.0. 0.2. 2.0. 0.1. 1.0. TA = 0. –0.1. A = +25. C/70. –1.0. – OFFSET VOLTAGE (mV)
CMP04–Typical Performance Characteristics 0.3 3.0 0.2 2.0 0.1 1.0 TA = 0 –0.1 A = +25 C/70 –1.0 – OFFSET VOLTAGE (mV)
CMP04–Typical Performance Characteristics 0.3 80 3.0 0.2 2.0 60 0.1 1.0 TA = 0
C 0 40 0 T –0.1 A = +25
C/70
C –1.0 – OFFSET VOLTAGE (mV) 20 OS – INPUT BIAS CURRENT (nA) V –0.2 I B – INPUT OFFSET CURRENT (nA) –2.0 I OS –0.3 0 –3.0 –60 –40 –20 0 20 40 60 80 100 120 140 0 5 10 15 20 25 30 35 40 –60 –40 –20 0 20 40 60 80 100 120 140 TEMPERATURE (
C) V+ – SUPPLY VOLTAGE (VDC) TEMPERATURE (
C)
TPC 1. Offset Voltage vs. TPC 2. Input Bias Current vs. V+ TPC 3. Input Offset Current vs. Temperature and Temperature Temperature
1.1 10 160 ) 150 OUT OF SATURATION DC 0.9 TA = 0
C 140 1.0 mV) 130 0.7 120 T A = +25
C 0.1 110 TA = +70
C 0.5 100 90 0.01 – VOLTAGE GAIN (V/ SUPPLY CURRENT (mA) V 0.3 – SATURATION VOLTAGE (V A 80 TA = +25
C OLV 70 0.1 0.001 60 0 5 10 15 20 25 30 35 40 0.01 0.1 1.0 10 100 –60 –40 –20 0 20 40 60 80 100 120 140 SUPPLY VOLTAGE (VDC) IO – OUTPUT SINK CURRENT (mA) TEMPERATURE (
C)
TPC 4. Voltage Gain vs. TPC 5. Supply Current vs. Supply TPC 6. Output Voltage vs. Output Temperature Voltage Current and Temperature
6.0 6.0 INPUT OVERDRIVE = INPUT OVERDRIVE = TA = 25
C 5.0 5.0mV 5.0 100mV 5V 4.0 DC 4.0 20mV (V) V 20mV O 3.0 IN (V) 3.0 V 5.1k
OV 5mV 2.0 2.0 100mV VOUT OUTPUT VOLTAGE 1.0 OUTPUT VOLTAGE 1.0 5VDC 0 0 5.1k
0 V 0 IN V –50 OUT (mV) –50 (mV) INV IN –100 V –100 TA = 25
C INPUT VOLTAGE INPUT VOLTAGE 0 0.5 1.0 1.5 2.0 0 0.5 1.0 1.5 2.0 TIME (
s) TIME (
s)
TPC 7. Response Time for Various Input TPC 8. Response Time for Various Input Overdrives—Negative Transition Overdrives—Positive Transition –4– REV. E Document Outline FEATURES GENERAL DESCRIPTION PIN CONNECTIONS TYPICAL INTERFACE SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ELECTRICAL CHARACTERISTICS Typical Performance Characteristics TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE Revision History
