Datasheet HMC874LC3C (Analog Devices) - 2
Description20 Gbps Clocked Comparator
Pages / Page12 / 2 — HMC874LC3C. 20 Gbps CLOCKED COMPARATOR. Clock Characteristics. DC Output …
File Format / SizePDF / 677 Kb
HMC874LC3C. 20 Gbps CLOCKED COMPARATOR. Clock Characteristics. DC Output Characteristics, Vcco = +2.0 V, V = 0 V
HMC874LC3C 20 Gbps CLOCKED COMPARATOR Clock Characteristics DC Output Characteristics, Vcco = +2.0 V, V = 0 V
HMC874LC3C
v07.0616
Parameter Conditions Min. Typ. Max Units Clock Input Impedance Each Pin 50 Ω T Clock to Data Output Delay, tdp 120 ps Clock Input Range 1.6 2.0 2.4 V M Clock Max Frequency, fmax 25 GHz S - S
DC Output Characteristics, Vcco = +2.0 V, V = 0 V tt
R Parameter Conditions Min. Typ. Max Units O Output Voltage High Level, Voh 1.03 1.09 1.14 V Output Voltage Low Level, Vol 0.65 0.71 0.81 V AT Output Voltage Differential Swing 440 760 980 mVpp R A P
AC Performance
Parameter Conditions Min. Typ. Max Units OM Propagation Delay - tPD, tPDL, tPDH VOD = 500 mV 80 85 110 ps C Propagation Delay, Temperature Coefficient 0.45 ps / °C Propagation Delay Skew VOD - 500 mV 10 ps (Rising to Falling Transition) VOD[1] Dispersion 50 mV <VOD <1V 10 ps tPD vs. Common Mode Dispersion, VOD = 500 mV 8 ps -1.75 V <Vcm <1.75 V Noise (RTI) 5.9 nV/√(Hz) RTI Equivalent Input Bandwidth [2] 8.6 9.3 12 GHz Deterministic Jitter at 10 Gbps Deterministic Jitter (pp) 2 ps with ±100 mV Overdrive Random Jitter at 10 Gbps Random Jitter (rms) 0.2 ps rms with ±100 mV Overdrive Input Signal Minimum Pulse Width VCM = 0; ±100 mV Overdrive 60 ps Q / QB Rise Time From 20% to 80% 24 ps Q / QB Fall Time From 20% to 80% 15 ps [1] VOD is the input overdrive voltage, for example, (V - V - V ) where V = input offset voltage. INP INN OS OS [2] Equivalent Input Bandwidth is calculated with the following formula: Bweq=0.22/√ (TRCOMP2-TRIN2) where TRIN is the 20%/80% transition time of a quasi-Gaussian signal applied to the comparator input, and TRCOMP is the effective transition time digitized by the comparator. For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
2
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Outline Drawing Package Information Evaluation PCB CLK, CLK Interfacing Resistor Network Bias Tee
