Datasheet ADCMP561, ADCMP562 (Analog Devices) - 8
DescriptionDual High Speed PECL Comparators
Pages / Page14 / 8 — ADCMP561/ADCMP562. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 3.0. …
File Format / SizePDF / 273 Kb
ADCMP561/ADCMP562. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 3.0. 2.80. 2.78. 2.5. 2.76. 2.0. 2.74. 1.5. 2.72. IN = 0V). 1.0. – 2.70. 2.68. 0.5
ADCMP561/ADCMP562 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 3.0 2.80 2.78 2.5 2.76 2.0 2.74 1.5 2.72 IN = 0V) 1.0 – 2.70 2.68 0.5
VCC = +5.0 V, VEE = –5.2 V, VDD = +3.3 V, TA = 25°C, unless otherwise noted.
µ
A)
µ
A) 2.74 1.5 2.72 IN = 0V) 1.0 – 2.70 2.68 0.5 (+IN = 3V, 2.66 0 INPUT BIAS CURRENT ( +IN INPUT BIAS CURRENT ( 2.64 –0.5 2.62 –1.0
04687-0-013
2.60
04687-0-016
–2.5 –1.5 –0.5 0.5 1.5 2.5 3.5 –40 –20 0 20 40 60 80 NONINVERTING INPUT VOLTAGE (INVERTING VOLTAGE = 0V) TEMPERATURE (
C)
Figure 6. Input Bias Current vs. Input Voltage Figure 9. Input Bias Current vs. Temperature
2.00 2.6 1.95 2.4 1.90 1.85 2.2 1.80 1.75 2.0 1.70 1.8 1.65 OFFSET VOLTAGE (mV) OUTPUT RISE AND FALL (V) 1.60 1.6 1.55 1.50
04687-0-014
1.4
04687-0-017
–40 –20 0 20 40 60 80 0 0.25 0.50 0.75 1.00 1.25 1.50 1.75 2.00 TEMPERATURE (
C) TIME (ns)
Figure 7. Input Offset Voltage vs. Temperature Figure 10. Rise and Fall of Outputs vs. Time
575 500 570 495 565 490 560 485 555 480 550 475 TIME (ps) 545 TIME (ps) 470 540 465 535 460 530 455 525
04687-0-015
450
04687-0-018
–40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 –40 –30 –20 –10 0 10 20 30 40 50 60 70 80 90 TEMPERATURE (
C) TEMPERATURE (
C)
Figure 8. Rise Time vs. Temperature Figure 11. Fall Time vs. Temperature Rev. B | Page 8 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TIMING INFORMATION APPLICATIONS INFORMATION CLOCK TIMING RECOVERY OPTIMIZING HIGH SPEED PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
