Datasheet ADCMP567 (Analog Devices) - 5
DescriptionDual Ultrafast Voltage Comparator
Pages / Page14 / 5 — Data Sheet. ADCMP567. ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL …
RevisionA
File Format / SizePDF / 167 Kb
Data Sheet. ADCMP567. ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL CONSIDERATIONS. Parameter Rating. ESD CAUTION
Data Sheet ADCMP567 ABSOLUTE MAXIMUM RATINGS Table 2 THERMAL CONSIDERATIONS Parameter Rating ESD CAUTION
Data Sheet ADCMP567 ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL CONSIDERATIONS Parameter Rating
The ADCMP567 LFCSP 32-lead package option has a θJA Supply Voltages (junction-to-ambient thermal resistance) of 27.2°C/W in still air. Positive Supply Voltage (VCC to GND) −0.5 V to +6.0 V Negative Supply Voltage (VEE to GND) −6.0 V to +0.5 V
ESD CAUTION
Logic Supply Voltage (VDD to GND) −0.5 V to +6.0 V Ground Voltage Differential −0.5 V to +0.5 V Input Voltages Input Common-Mode Voltage −3.0 V to +4.0 V Differential Input Voltage −7.0 V to +7.0 V Input Voltage, Latch Controls −0.5 V to +5.5 V Output Current 30 mA Temperature Operating Temperature, Ambient −40°C to +85°C Operating Temperature, Junction 125°C Storage Temperature Range −65°C to +150°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. A | Page 5 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TIMING INFORMATION APPLICATIONS INFORMATION CLOCK TIMING RECOVERY OPTIMIZING HIGH SPEED PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
