Datasheet RH119 (Analog Devices) - 4
Description | High Performance Dual Comparator |
Pages / Page | 4 / 4 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Offset Voltage. Input Bias … |
Revision | D |
File Format / Size | PDF / 672 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Input Offset Voltage. Input Bias Current. Input Offset Current. Open-Loop Gain
RH119
TYPICAL PERFORMANCE CHARACTERISTICS Input Offset Voltage Input Bias Current Input Offset Current
6 2000 500 VS = 15V VS = 15V VS = 15V VCM = 0V VCM = 0V V 4 400 CM = 0V RS = 5k 1600 2 300 1200 0 200 800 –2 100 INPUT BIAS CURRENT (nA) INPUT OFFSET VOLTAGE (mV) 400 INPUT OFFSET CURRENT (nA) –4 0 0 –6 –100 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH119 G02 RH119 G01 RH119 G03
Open-Loop Gain Common Mode Rejection Ratio Input Offset Voltage
70 150 6 VS = 15V VS = 15V VS = 15V R 60 140 4 S = 50Ω 50 130 2 40 120 0 30 110 –2 OPEN-LOOP GAIN (V/mV) INPUT OFFSET VOLTAGE (mV) 20 100 –4 COMMON MODE REJECTION RATIO (dB) 10 90 –6 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH119 G04 RH119 G05 RH119 G06 I.D.No.66-10-0176 Rev. D 4 04/19 www.analog.com For more information www.analog.com ANALOG DEVICES, INC. 1990–2019 Document Outline Description Burn-In Circuit Package/Order Information Absolute Maximum Ratings Table 1: Electrical Characteristics Table 1A: Electrical Characteristics Electrical Characteristics Table 2: Electrical Test Requirements Total Dose Bias Circuit Revision History
