LT3093 ABSOLUTE MAXIMUM RATINGS (Note 1) IN Pin Voltage SET Pin Current (Note 4) ... ±10mA with Respect to GND Pin ...–22V, 0.3V OUTS Pin Voltage EN/UV Pin Voltage with Respect to IN Pin (Note 2) ...–0.3V, 22V with Respect to IN Pin (Note 2) ...–0.3V, 30V with Respect to GND Pin ..±22V with Respect to GND Pin ..±22V OUTS Pin Current (Note 4) ... ±10mA PG Pin Voltage SET-to-OUTS Differential (Note 5) ..±22V with Respect to IN Pin (Note 2) ...–0.3V, 30V OUT Pin Voltage with Respect to GND Pin ...–0.3V, 22V with Respect to IN Pin (Note 2) ...–0.3V, 22V PGFB Pin Voltage with Respect to GND Pin ..±22V with Respect to IN Pin (Note 2) ...–0.3V, 30V OUT-to-OUTS Differential (Note 6) ..±22V with Respect to GND Pin ..±22V Output Short-Circuit Duration .. Indefinite ILIM Pin Voltage Operating Junction Temperature Range (Note 3) with Respect to IN Pin (Note 2) ...–0.3V, 22V E-, I-Grades ... –40°C to 125°C VIOC Pin Voltage H-Grade ... –40°C to 150°C with Respect to IN Pin (Note 2) ...–0.3V, 22V Storage Temperature Range .. –65°C to 150°C with Respect to GND Pin ...–22V, 0.3V Lead Temperature (Soldering, 10 sec) SET Pin Voltage MSE Package Only ..300°C with Respect to IN Pin (Note 2) ...–0.3V, 22V with Respect to GND Pin ..±22V PIN CONFIGURATION TOP VIEW TOP VIEW IN 1 12 OUT IN 1 12 OUT IN 2 11 OUT IN 2 11 OUT EN/UV 3 13 10 OUTS EN/UV 3 13 10 OUTS PG 4 IN 9 GND PG 4 IN 9 GND PGFB 5 8 SET PGFB 5 8 SET I 6 LIM 7 VIOC I VIOC LIM 6 7 MSE PACKAGE DD PACKAGE 12-LEAD PLASTIC MSOP 12-LEAD (3mm × 3mm) PLASTIC DFN T T JMAX = 150°C, θJA = 33°C/W, θJC = 8°C/W JMAX = 150°C, θJA = 34°C/W, θJC = 5.5°C/W EXPOSED PAD (PIN 13) IS IN, MUST BE SOLDERED TO PCB EXPOSED PAD (PIN 13) IS IN, MUST BE SOLDERED TO PCB Rev. 0 For more information www.analog.com 3 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Application Package Description Typical Application Related Parts
