Datasheet ADP1764 (Analog Devices)
Description4 A, Low VIN, Low Noise, CMOS Linear Regulator
Pages / Page20 / 1 — 4 A, Low VIN, Low Noise,. CMOS Linear Regulator. Data Sheet. ADP1764. …
RevisionA
File Format / SizePDF / 789 Kb
4 A, Low VIN, Low Noise,. CMOS Linear Regulator. Data Sheet. ADP1764. FEATURES. TYPICAL APPLICATION CIRCUITS
Datasheet ADP1764 Analog Devices, Revision: A
4 A, Low VIN, Low Noise, CMOS Linear Regulator Data Sheet ADP1764 FEATURES TYPICAL APPLICATION CIRCUITS 4 A maximum output current ADP1764 V V IN = 1.8V OUT = 1.5V Low input voltage supply range VIN VOUT C C IN OUT V 22µF 22µF IN = 1.10 V to 1.98 V, no external bias supply required SENSE Fixed output voltage range (V R ON OUT_FIXED): 0.55 V to 1.5 V PULL-UP 100kΩ EN Adjustable output voltage range (V PG PG OFF OUT_ADJ): 0.5 V to 1.5 V Ultralow noise: 2 μV rms, 100 Hz to 100 kHz SS VADJ Noise spectral density: 5 nV/√Hz at 10 kHz; 4 nV/√Hz at 100 kHz CSS VREG REFCAP 10nF Low dropout voltage: 47 mV typical at 4 A load C C REG GND REF
01 0
1µF 1µF
9-
Operating supply current: 5 mA typical at no load
93 14
±1.5% fixed output voltage accuracy over line, load, and
Figure 1. Fixed Output Operation
temperature ADP1764 V V Excellent power supply rejection ratio (PSRR) performance IN = 1.8V OUT = 1.5V VIN VOUT C C 69 dB typical at 10 kHz at 4 A load IN OUT 22µF 22µF SENSE 46 dB typical at 100 kHz at 4 A load RPULL-UP ON Excellent load/line transient response 100kΩ EN PG PG OFF Soft start to reduce inrush current SS VADJ Optimized for small 22 μF ceramic capacitors C R SS VREG REFCAP ADJ Current-limit and thermal overload protection 10nF 10kΩ C C
2
REG GND REF
00
Power-good indicator 1µF 1µF
9- 493 1
Precision enable
Figure 2. Adjustable Output Operation
16-lead, 3 mm × 3 mm LFCSP package
The ADP1764 is available in fixed output voltages ranging from
0.55 V to 1.5 V. The output voltage (VOUT) of the adjustable
Regulation to noise sensitive applications such as radio
output model can be set from 0.5 V to 1.5 V through an
frequency (RF) transceivers, analog-to-digital converter
external resistor connected between VADJ and ground.
(ADC) and digital-to-analog converter (DAC) circuits,
The ADP1764 has an externally programmable soft start time by
phase-locked loops (PLLs), voltage controlled oscillators
connecting a capacitor to the SS pin. Short-circuit and thermal
(VCOs) and clocking integrated circuits
overload protection circuits prevent damage in adverse conditions.
Field-programmable gate array (FPGA) and digital signal
The ADP1764 is available in a small, 16-lead LFCSP package for
processor (DSP) supplies
the smallest footprint solution to meet a variety of applications.
Medical and healthcare Industrial and instrumentation Table 1. Related Devices Input Maximum Fixed/ GENERAL DESCRIPTION Model Voltage Current Adjustable Package
The ADP1764 is a low noise, low dropout (LDO) linear ADP1761 1.10 V to 1.98 V 1 A Fixed/ 16-lead adjustable LFCSP regulator. It is designed to operate from a single input supply ADP1762 1.10 V to 1.98 V 2 A Fixed/ 16-lead with an input voltage as low as 1.10 V without the requirement adjustable LFCSP of an external bias supply to increase efficiency and provide up ADP1763 1.10 V to 1.98 V 3 A Fixed/ 16-lead to 4 A of output current (IOUT). adjustable LFCSP The low 47 mV typical dropout voltage at a 4 A load allows the ADP1740/ 1.6 V to 3.6 V 2 A Fixed/ 16-lead ADP1741 adjustable LFCSP ADP1764 to operate with a small headroom while maintaining ADP1752/ 1.6 V to 3.6 V 0.8 A Fixed/ 16-lead regulation and providing better efficiency. ADP1753 adjustable LFCSP The ADP1764 is optimized for stable operation with small 22 μF ADP1754/ 1.6 V to 3.6 V 1.2 A Fixed/ 16-lead ADP1755 adjustable LFCSP ceramic output capacitors. The ADP1764 delivers optimal transient performance with minimal printed circuit board (PCB) area.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL APPLICATION CIRCUITS REVISION HISTORY SPECIFICATIONS INPUT AND OUTPUT CAPACITOR: RECOMMENDED SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL DATA THERMAL RESISTANCE/PARAMETER ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SOFT START FUNCTION ADJUSTABLE OUTPUT VOLTAGE ENABLE FEATURE POWER-GOOD (PG) FEATURE APPLICATIONS INFORMATION CAPACITOR SELECTION Output Capacitor Input Bypass Capacitor Input and Output Capacitor Properties UNDERVOLTAGE LOCKOUT CURRENT-LIMIT AND THERMAL OVERLOAD PROTECTION PARALLELING ADP1764 DEVICES FOR HIGH CURRENT APPLICATIONS THERMAL CONSIDERATIONS PCB LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
