Datasheet ADP1720 (Analog Devices) - 10
Description50 mA, High Voltage, Micropower Linear Regulator
Pages / Page16 / 10 — ADP1720. THEORY OF OPERATION. ADJUSTABLE OUTPUT VOLTAGE. (ADP1720 …
File Format / SizePDF / 372 Kb
ADP1720. THEORY OF OPERATION. ADJUSTABLE OUTPUT VOLTAGE. (ADP1720 ADJUSTABLE). OUT. CURRENT LIMIT. THERMAL PROTECT. SHUTDOWN. GND/ADJ
ADP1720 THEORY OF OPERATION ADJUSTABLE OUTPUT VOLTAGE (ADP1720 ADJUSTABLE) OUT CURRENT LIMIT THERMAL PROTECT SHUTDOWN GND/ADJ
link to page 1 link to page 1 link to page 10
The ADP1720 is a low dropout, BiCDMOS linear regulator that
operates from a 4 V to 28 V input rail and provides up to 50 mA
of output current. Ground current in shutdown mode is typically The ADP1720 adjustable version can have its output voltage 700 nA. The ADP1720 is stable and provides high power supply set over a 1.225 V to 5.0 V range. The output voltage is set by rejection ratio (PSRR) and excellent line and load transient connecting a resistive voltage divider from OUT to ADJ. The response with just a small 1 μF ceramic output capacitor. output voltage is calculated using the equation VOUT = 1.225 V (1 + R1/R2) (1)
IN OUT
where: R1 is the resistor from OUT to ADJ. R2 is the resistor from ADJ to GND.
To make calculation of R1 and R2 easier, Equation 1 can be rearranged as follows:
SHUTDOWN
R1 = R2 [(VOUT /1.225) – 1] (2)
GND/ADJ
The maximum bias current into ADJ is 100 nA; therefore,
REFERENCE EN
when less than 0.5% error is due to the bias current, use values less than 60 kΩ for R2. 19 0
GND
1- 11 06 Figure 19. Internal Block Diagram Internally, the ADP1720 consists of a reference, an error ampli- fier, a feedback voltage divider, and a DMOS pass transistor. Output current is delivered via the DMOS pass device, which is controlled by the error amplifier. The error amplifier compares the reference voltage with the feedback voltage from the output and amplifies the difference. If the feedback voltage is lower than the reference voltage, the gate of the DMOS device is pulled lower, allowing more current to pass and increasing the output voltage. If the feedback voltage is higher than the reference voltage, the gate of the PNP device is pulled higher, allowing less current to pass and decreasing the output voltage. The ADP1720 is available in two versions, one with fixed output voltage options (see Figure 1) and one with an adjustable output voltage (see Figure 2). The fixed output voltage options are set internally to either 5.0 V or 3.3 V, using an internal feedback network. The adjustable output voltage can be set to between 1.225 V and 5.0 V by an external voltage divider connected from OUT to ADJ. The ADP1720 uses the EN pin to enable and disable the OUT pin under normal operating conditions. When EN is high, OUT turns on; when EN is low, OUT turns off. For automatic startup, EN can be tied to IN. Rev. A | Page 10 of 16 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUITS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ADJUSTABLE OUTPUT VOLTAGE(ADP1720 ADJUSTABLE) APPLICATIONS INFORMATION CAPACITOR SELECTION Output Capacitor Input Bypass Capacitor Input and Output Capacitor Properties CURRENT LIMIT AND THERMAL OVERLOAD PROTECTION THERMAL CONSIDERATIONS PRINTED CIRCUIT BOARD LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
