Datasheet UF4001, UF4002, UF4003, UF4004, UF4005, UF4006, UF4007 (Vishay) - 2
ManufacturerVishay
DescriptionUltrafast Plastic Rectifier
Pages / Page5 / 2 — ELECTRICAL CHARACTERISTICS. THERMAL CHARACTERISTICS. ORDERING …
File Format / SizePDF / 73 Kb
ELECTRICAL CHARACTERISTICS. THERMAL CHARACTERISTICS. ORDERING INFORMATION. RATINGS AND CHARACTERISTICS CURVES
ELECTRICAL CHARACTERISTICS THERMAL CHARACTERISTICS ORDERING INFORMATION RATINGS AND CHARACTERISTICS CURVES
UF4001, UF4002, UF4003, UF4004, UF4005, UF4006, UF4007 www.vishay.com Vishay General Semiconductor
(TA = 25 °C unless otherwise noted) PARAMETER TEST CONDITIONS SYMBOL UF4001 UF4002 UF4003 UF4004 UF4005 UF4006 UF4007 UNIT Maximum instantaneous 1.0 A V forward voltage F (1) 1.0 1.7 V Maximum DC reverse TA = 25 °C 10 current at rated DC IR μA blocking voltage TA = 100 °C 50 Maximum reverse IF = 0.5 A, IR = 1.0 A, t recovery time I rr 50 75 ns rr = 0.25 A Typical junction 4.0 V, 1 MHz C capacitance J 17 pF Note (1) Pulse test: 300 μs pulse width, 1 % duty cycle
(TA = 25 °C unless otherwise noted) PARAMETER SYMBOL UF4001 UF4002 UF4003 UF4004 UF4005 UF4006 UF4007 UNIT RθJA (1) 60 Typical thermal resistance °C/W RθJL (1) 15 Note (1) Thermal resistance from junction to ambient at 0.375" (9.5 mm) lead length
(Example) PREFERRED P/N UNIT WEIGHT (g) PREFERRED PACKAGE CODE BASE QUANTITY DELIVERY MODE UF4007-E3/54 0.33 54 5500 13" diameter paper tape and reel UF4007-E3/73 0.34 73 3000 Ammo pack packaging UF4007-M3/54 0.33 54 5500 13" diameter paper tape and reel UF4007-M3/73 0.34 73 3000 Ammo pack packaging
(TA = 25 °C unless otherwise noted) 1.0 30 T = 55 °C A 8.3 ms Single Half Sine-Wave ent (A) 25 ent (A) Curr 20 ge Curr 0.5 ur 15 S d Rectified d 10 5 erage Forwar Resistive or Inductive Load Peak Forwar v A 0.375" (9.5 mm) Lead Length 0 0 20 40 60 80 100 120 140 160 1 10 100 Ambient Temperature (°C) Number of Cycles at 60 Hz Fig. 1 - Maximum Forward Current Derating Curve Fig. 2 - Maximum Non-Repetitive Peak Forward Surge Current Revision: 06-Apr-2020 2 Document Number: 88755 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
