Datasheet AD835 (Analog Devices) - 3
Description250 MHz, Voltage Output 4-Quadrant Multiplier
Pages / Page14 / 3 — Data Sheet. AD835. SPECIFICATIONS. Table 1. Parameter. Conditions. Min. …
RevisionE
File Format / SizePDF / 259 Kb
Data Sheet. AD835. SPECIFICATIONS. Table 1. Parameter. Conditions. Min. Typ. Max. Unit
Data Sheet AD835 SPECIFICATIONS Table 1 Parameter Conditions Min Typ Max Unit
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
TA = 25°C, VS = ±5 V, RL = 150 Ω, CL ≤ 5 pF, unless otherwise noted.
Table 1. Parameter Conditions Min Typ Max Unit
TRANSFER FUNCTION (X1− X2)(Y1−Y ) W = 2 + Z U INPUT CHARACTERISTICS (X, Y) Differential Voltage Range VCM = 0 V ±1 V Differential Clipping Level ±1.21 ±1.4 V Low Frequency Nonlinearity X = ±1 V, Y = 1 V 0.3 0.51 % FS Y = ±1 V, X = 1 V 0.1 0.31 % FS vs. Temperature T 2 MIN to TMAX X = ±1 V, Y = 1 V 0.7 % FS Y = ±1 V, X = 1 V 0.5 % FS Common-Mode Voltage Range −2.5 +3 V Offset Voltage ±3 ±201 mV vs. Temperature T 2 MIN to TMAX ±25 mV CMRR f ≤ 100 kHz; ±1 V p-p 701 dB Bias Current 10 201 µA vs. Temperature T 2 MIN to TMAX 27 µA Offset Bias Current 2 µA Differential Resistance 100 kΩ Single-Sided Capacitance 2 pF Feedthrough, X X = ±1 V, Y = 0 V −461 dB Feedthrough, Y Y = ±1 V, X = 0 V −601 dB DYNAMIC CHARACTERISTICS −3 dB Small Signal Bandwidth 150 250 MHz −0.1 dB Gain Flatness Frequency 15 MHz Slew Rate W = −2.5 V to +2.5 V 1000 V/µs Differential Gain Error, X f = 3.58 MHz 0.3 % Differential Phase Error, X f = 3.58 MHz 0.2 Degrees Differential Gain Error, Y f = 3.58 MHz 0.1 % Differential Phase Error, Y f = 3.58 MHz 0.1 Degrees Harmonic Distortion X or Y = 10 dBm, second and third harmonic Fund = 10 MHz −70 dB Fund = 50 MHz −40 dB Settling Time, X or Y To 0.1%, W = 2 V p-p 20 ns SUMMING INPUT (Z) Gain From Z to W, f ≤ 10 MHz 0.990 0.995 −3 dB Small Signal Bandwidth 250 MHz Differential Input Resistance 60 kΩ Single-Sided Capacitance 2 pF Maximum Gain X, Y to W, Z shorted to W, f = 1 kHz 50 dB Bias Current 50 µA Rev. E | Page 3 of 14 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC THEORY SCALING ADJUSTMENT APPLICATIONS INFORMATION MULTIPLIER CONNECTIONS WIDEBAND VOLTAGE-CONTROLLED AMPLIFIER AMPLITUDE MODULATOR SQUARING AND FREQUENCY DOUBLING OUTLINE DIMENSIONS ORDERING GUIDE
