Datasheet AD835 (Analog Devices) - 4
Description250 MHz, Voltage Output 4-Quadrant Multiplier
Pages / Page14 / 4 — AD835. Data Sheet. Parameter. Conditions. Min. Typ. Max. Unit
RevisionE
File Format / SizePDF / 259 Kb
AD835 Data Sheet Parameter Conditions Min Typ Max Unit
OUTPUT CHARACTERISTICS Voltage Swing ±2.2 ±2.5 V vs. Temperature T 2 MIN to TMAX ±2.0 V Voltage Noise Spectral Density X = Y = 0 V, f < 10 MHz 50 nV/√Hz Offset Voltage ±25 ±751 mV vs. Temperature3 T 2 MIN to TMAX ±10 mV Short-Circuit Current 75 mA Scale Factor Error ±5 ±81 % FS vs. Temperature T 2 MIN to TMAX ±9 % FS Linearity (Relative Error)4 ±0.5 ±1.01 % FS vs. Temperature T 2 MIN to TMAX ±1.25 % FS POWER SUPPLIES Supply Voltage For Specified Performance ±4.5 ±5 ±5.5 V Quiescent Supply Current 16 251 mA vs. Temperature T 2 MIN to TMAX 26 mA PSRR at Output vs. VP +4.5 V to +5.5 V 0.51 %/V PSRR at Output vs. VN −4.5 V to −5.5 V 0.5 %/V 1 All minimum and maximum specifications are guaranteed. These specifications are tested on all production units at final electrical test. 2 TMIN = −40°C, TMAX = 85°C. 3 Normalized to zero at 25°C. 4 Linearity is defined as residual error after compensating for input offset, output voltage offset, and scale factor errors. Rev. E | Page 4 of 14 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC THEORY SCALING ADJUSTMENT APPLICATIONS INFORMATION MULTIPLIER CONNECTIONS WIDEBAND VOLTAGE-CONTROLLED AMPLIFIER AMPLITUDE MODULATOR SQUARING AND FREQUENCY DOUBLING OUTLINE DIMENSIONS ORDERING GUIDE
