Datasheet AD834 (Analog Devices) - 5
Description500 MHz Four-Quadrant Multiplier
Pages / Page20 / 5 — Data Sheet. AD834. ABSOLUTE MAXIMUM RATINGS Table 2. CHIP DIMENSIONS AND …
RevisionF
File Format / SizePDF / 353 Kb
Data Sheet. AD834. ABSOLUTE MAXIMUM RATINGS Table 2. CHIP DIMENSIONS AND BONDING DIAGRAM. Parameter. Ratings. 834. P M D. I 1987
Data Sheet AD834 ABSOLUTE MAXIMUM RATINGS Table 2 CHIP DIMENSIONS AND BONDING DIAGRAM Parameter Ratings 834 P M D I 1987
Data Sheet AD834 ABSOLUTE MAXIMUM RATINGS Table 2. CHIP DIMENSIONS AND BONDING DIAGRAM Parameter Ratings Y1 X2 1 8
Supply Voltage (+VS to −VS) 18 V
A Y2 834 X1 2 7
Internal Power Dissipation 500 mW
P M D A
Input Voltages (X1, X2, Y1, Y2) +V
D
S
I 1987 0.054 (1.37)
Operating Temperature Ranges
US A
Commercial, AD834J Only 0°C to 70°C
+V –V S S
Industrial, AD834A Only −40°C to +85°C
3 6
Military AD834S/883B Only −55°C to +125°C Storage Temperature Range (Q) −65°C to +150°C Storage Temperature Range (R, N) −65°C to +125°C
4 5
Lead Temperature (Soldering, 60 sec) 300°C
W2 W1 0.054 (1.37)
ESD Rating 500 V
NOTES
003 Stresses above those listed under Absolute Maximum Ratings
1. DIMENSIONS SHOWN IN INCHES AND (mm). CONTACT FACTORY FOR LATEST DIMENSIONS.
00894- may cause permanent damage to the device. This is a stress Figure 2. Metallization Photograph rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute
ESD CAUTION
maximum rating conditions for extended periods may affect device reliability.
THERMAL CHARACTERISTICS Table 3. Package θJA θJA Unit
8-Lead CERDIP (Q) 110 110 °C/W 8-Lead SOIC (R) 165 165 °C/W 8-Lead PDIP (N) 99 99 °C/W Rev. F | Page 5 of 20 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Absolute Maximum Ratings Thermal Characteristics Chip Dimensions and Bonding Diagram ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Explanation of Typical Performance Characteristics and Test Circuits Theory of Operation Transfer Function Biasing the Output Transformer Coupling Wideband Multiplier Connections Power Measurement (Mean-Square and RMS) Frequency Doubler Wideband Three-Signal Multiplier/Divider Outline Dimensions Ordering Guide
