Datasheet AD632 (Analog Devices)
Description | Internally Trimmed Precision IC Multiplier |
Pages / Page | 12 / 1 — Internal y Trimmed. Precision IC Multiplier. Data Sheet. AD632. FEATURES. … |
Revision | D |
File Format / Size | PDF / 301 Kb |
Internal y Trimmed. Precision IC Multiplier. Data Sheet. AD632. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Internal y Trimmed Precision IC Multiplier Data Sheet AD632 FEATURES FUNCTIONAL BLOCK DIAGRAM Pretrimmed to ±0.5% maximum 4-quadrant error STABLE +VS All inputs (X, Y, and Z) differential, high impedance for REFERENCE AND BIAS –VS [(X1 − X2)(Y1 − Y2)/10] + Z2 transfer function Scale-factor adjustable to provide up to ×10 gain TRANSFER FUNCTION X1 Low noise design: 90 mV rms, 10 Hz to 10 kHz (X V-I V 1 – X2) (Y1 – Y2) O = A – (Z1 – Z2) X 10 Low cost, monolithic construction 2 TRANSLINEAR MULTIPLIER Excellent long-term stability ELEMENT Y1 V-I APPLICATIONS Y A OUT 2 HIGH GAIN High quality analog signal processing Z1 OUTPUT Z V-I 0.75 ATTEN AMPLIFIER Differential ratio and percentage computations 2 2.7kΩ
007
Algebraic and trigonometric function synthesis VOS 25kΩ
09040-
Accurate voltage controlled oscillators and filters
Figure 1.
GENERAL DESCRIPTION
The AD632 is an internally trimmed monolithic four-quadrant rejection. The effectiveness of the variable gain capability is multiplier/divider. The AD632B has a maximum multiplying enhanced by the inherent low noise of the AD632 at 90 µV rms. error of ±0.5% without external trims.
PRODUCT HIGHLIGHTS
Excellent supply rejection, low temperature coefficients, and 1. Guaranteed performance over temperature. long-term stability of the on-chip thin film resistors and buried 2. The AD632A and AD632B are specified for maximum zener reference preserve accuracy even under adverse conditions. multiplying errors of ±1.0% and ±0.5% of full scale, The simplicity and flexibility of use provide an attractive alternative respectively, at +25°C and are rated for operation from approach to the solution of complex control functions. −25°C to +85°C. The AD632 is pin-for-pin compatible with the industry 3. Maximum multiplying errors of ±2.0% (AD632S) and standard AD532 but with improved specifications and a fully ±1.0% (AD632T) are guaranteed over the extended differential high impedance Z input. The AD632 is capable of temperature range of −55°C to +125°C. providing gains of up to ×10, frequently eliminating the need 4. High reliability. for separate instrumentation amplifiers to precondition the 5. The AD632S and AD632T series are available with MIL- inputs. The AD632 can be effectively employed as a variable STD-883 Level B screening. gain differential input amplifier with high common-mode 6. All devices are available in either the hermetically sealed TO-100 metal can or ceramic DIP package.
Rev. D Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©1979–2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Absolute Maximum Ratings Thermal Resistance Pin Configurations and Function Descriptions Typical Performance Characteristics Operation As a Multiplier Operation As a Divider Outline Dimensions Ordering Guide
