Datasheet AD534 (Analog Devices) - 3
DescriptionInternally Trimmed Precision IC Multiplier
Pages / Page20 / 3 — Data Sheet. AD534. SPECIFICATIONS. Table 1. AD534J. AD534K. AD534L. …
RevisionD
File Format / SizePDF / 334 Kb
Data Sheet. AD534. SPECIFICATIONS. Table 1. AD534J. AD534K. AD534L. Parameter. Min. Typ. Max. Unit
Data Sheet AD534 SPECIFICATIONS Table 1 AD534J AD534K AD534L Parameter Min Typ Max Unit
link to page 5 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
TA = 25°C, ±VS = ±15 V, RL ≥ 2 kΩ, all minimum and maximum specifications are guaranteed, unless otherwise noted.
Table 1. AD534J AD534K AD534L Parameter Min Typ Max Min Typ Max Min Typ Max Unit
MULTIPLIER PERFORMANCE Transfer Function (X  )(  ) (  )(  (  )(  1 X 2 1 Y Y2 X X Y Y ) X X Y Y )  Z 1 2 1 2 1 2 1 2  Z  Z 2 10 V 2 10 V 2 10 V Total Error1 (−10 V ≤ X, Y ≤ +10 V) ±1.02 ±0.52 ±0.252 % TA = TMIN to TMAX ±1.5 ±1.0 ±0.5 % Total Error vs. Temperature ±0.022 ±0.015 ±0.008 %/°C Scale Factor Error (SF = 10.000 V Nominal)3 ±0.25 ±0.1 ±0.1 % Temperature Coefficient of Scaling Voltage ±0.02 ±0.01 ±0.005 %/°C Supply Rejection (±15 V ± 1 V) ±0.01 ±0.01 ±0.01 % Nonlinearity, X (X = 20 V p-p, ±0.4 ±0.2 ±0.32 ±0.10 ±0.122 % Y = 10 V) Nonlinearity, Y (Y = 20 V p-p, X = 10 V) ±0.2 ±0.1 ±0.12 ±0.005 ±0.12 % Feedthrough4, X (Y Nulled, ±0.3 ±0.15 ±0.32 ±0.05 ±0.122 % X = 20 V p-p 50 Hz) Feedthrough4, Y (X Nulled, ±0.01 ±0.01 ±0.12 ±0.003 ±0.12 % Y = 20 V p-p, 50 Hz) Output Offset Voltage ±5 ±302 ±2 ±152 ±2 ±102 mV Output Offset Voltage Drift 200 100 100 μV/°C DYNAMICS Small Signal BW (VOUT = 0.1 rms) 1 1 1 MHz 1% Amplitude Error (CLOAD = 1000 pF) 50 50 50 kHz Slew Rate (VOUT 20 p-p) 20 20 20 V/μs Settling Time (to 1%, D VOUT = 20 V) 2 2 2 μs NOISE Noise Spectral Density SF = 10 V 0.8 0.8 0.8 μV/√Hz SF = 3 V5 0.4 0.4 0.4 μV/√Hz Wideband Noise f = 10 Hz to 5 MHz 1 1 1 mV rms f = 10 Hz to 10 kHz 90 90 90 μV rms OUTPUT Output Voltage Swing ±112 ±112 ±112 V Output Impedance (f ≤ 1 kHz) 0.1 0.1 0.1 Ω Output Short-Circuit Current (RL = 0 Ω, TA = TMIN to TMAX) 30 30 30 mA Amplifier Open-Loop Gain (f = 50 Hz) 70 70 70 dB INPUT AMPLIFIERS (X, Y, and Z)6 Signal Voltage Range Differential or Common Mode ±10 ±10 ±10 V Operating Differential ±12 ±12 ±12 V Offset Voltage (X, Y) ±5 ±202 ±2 ±102 ±2 ±102 mV Offset Voltage Drift (X, Y) 100 50 50 μV/°C Offset Voltage (Z) ±5 ±302 ±2 ±152 ±2 ±102 mV Offset Voltage Drift (Z) 200 100 100 μV/°C CMRR 602 80 702 90 702 90 dB Rev. D | Page 3 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Functional Description Provides Gain with Low Noise Operation as a Multiplier Operation as a Squarer Operation as a Divider Operation as a Square Rooter Unprecedented Flexibility Applications Information Outline Dimensions Ordering Guide
