Datasheet AD534 (Analog Devices) - 10
DescriptionInternally Trimmed Precision IC Multiplier
Pages / Page20 / 10 — AD534. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 1000. (V). …
RevisionD
File Format / SizePDF / 334 Kb
AD534. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 1000. (V). OUTPUT, RL ≥ 2kΩ. L A N 12. ALL INPUTS, SF = 10V. 100. ) -p. IVE SI. T 10
AD534 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 1000 (V) OUTPUT, RL ≥ 2kΩ L A N 12 ALL INPUTS, SF = 10V 100 ) -p IVE SI T 10
Typical at 25°C, with ±VS = ±15 V dc, unless otherwise noted.
14 1000 (V) OUTPUT, RL ≥ 2kΩ L A N 12 G ALL INPUTS, SF = 10V 100 ) -p IVE SI p T 10 V A m ( EG H N 10 R UG X-FEEDTHROUGH 8 HRO IVE O T DT SI E E 1 F PO 6 Y-FEEDTHROUGH K PEA 4
3
0.1
02
8 10 12 14 16 18 20
200 5-
10 100 1k 10k 100k 1M 10M
5- 967
FREQUENCY (Hz) POSITIVE OR NEGATIVE SUPPLY (V)
67 0 09 Figure 7. Input/Output Signal Range vs. Supply Voltages Figure 10. AC Feedthrough vs. Frequency
800 1.5 700 ) Hz 600 V/ µ SCALING VOLTAGE = 10V A) Y ( T 1 500 (n SI SCALING VOLTAGE = 10V N NT E 400 D L A R CURRE T 300 AS 0.5 BI SPEC SCALING VOLTAGE = 3V 200 ISE O SCALING VOLTAGE = 3V N 100 0
4 1
0 –60 –40 –20 0 20 40 60 80 100 120 140
02 -02
10 100 1k 10k 100k
75 675-
TEMPERATURE (°C) FREQUENCY (Hz)
09 096 Figure 8. Bias Current vs. Temperature (X, Y, or Z Input) Figure 11. Noise Spectral Density vs. Frequency
90 100 80 s) 70 90 V rm µ CONDITIONS: 60 E ( 10Hz TO 10kHz BANDWIDTH B) TYPICAL FOR AG 80 d 50 T ALL INPUTS L RR ( VO 40 E CM IS 70 30 NO UT 20 P T 60 U O 10 0 50
-022
100 1k 10k 100k 1M 2.5 5.0 7.5 10.0
25-0 675
FREQUENCY (Hz)
75 09
SCALING VOLTAGE, SF (V)
096 Figure 9. Common-Mode Rejection Ratio vs. Frequency Figure 12. Wideband Noise vs. Scaling Voltage Rev. D | Page 10 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Functional Description Provides Gain with Low Noise Operation as a Multiplier Operation as a Squarer Operation as a Divider Operation as a Square Rooter Unprecedented Flexibility Applications Information Outline Dimensions Ordering Guide
