Datasheet AD532 (Analog Devices)
Description | Internally Trimmed Integrated Circuit Multiplier |
Pages / Page | 14 / 1 — Internally Trimmed. Integrated Circuit Multiplier. Data Sheet. AD532. … |
Revision | E |
File Format / Size | PDF / 348 Kb |
Internally Trimmed. Integrated Circuit Multiplier. Data Sheet. AD532. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Internally Trimmed Integrated Circuit Multiplier Data Sheet AD532 FEATURES FUNCTIONAL BLOCK DIAGRAM Pretrimmed to ±1.0% (AD532K) X V 1 X No external components required X2 Guaranteed ±1.0% maximum 4-quadrant error (AD532K) R R X Z Differential inputs for (X1 − X2) (Y1 − Y2)/10 V transfer function Monolithic construction, low cost Y1 V OUTPUT Y Y2 APPLICATIONS 10R VOS (X Multiplication, division, squaring, square rooting 1 – X2) (Y1 – Y2) R VOUT = 10V
-003
Algebraic computation
502
(WITH Z TIED TO OUTPUT)
00
Power measurements
Figure 1.
Instrumentation applications GUARANTEED PERFORMANCE OVER Available in chip form TEMPERATURE GENERAL DESCRIPTION
The AD532J and AD532K are specified for maximum multiplying The AD532 is the first pretrimmed, single chip, monolithic errors of ±2% and ±1% of full scale, respectively at 25°C, and multiplier/divider. It guarantees a maximum multiplying error are rated for operation from 0°C to 70°C. The AD532S has a of ±1.0% and a ±10 V output voltage without the need for any maximum multiplying error of ±1% of full scale at 25°C; it is external trimming resistors or output op amp. Because the AD532 also 100% tested to guarantee a maximum error of ±4% at the is internally trimmed, its simplicity of use provides design extended operating temperature limits of −55°C and +125°C. engineers with an attractive alternative to modular multipliers, All devices are available in either a hermetically sealed TO-100 and its monolithic construction provides significant advantages metal can or 14-lead D-14 side brazed ceramic DIP. The J, K, in size, reliability, and economy. Further, the AD532 can be a and S grade chips are also available. direct replacement for other IC multipliers that require external
ADVANTAGES OF ON THE CHIP TRIMMING OF
trim networks.
THE MONOLITHIC AD532 FLEXIBILITY OF OPERATION
1. True ratiometric trim for improved power supply rejection. The AD532 multiplies in four quadrants with a transfer function of 2. Reduced power requirements since no networks across (X1 − X2)(Y1 − Y2)/10 V, divides in two quadrants with a 10 V Z/ supplies are required. (X1 − X2) transfer function, and square roots in one quadrant 3. More reliable because standard monolithic assembly with a transfer function of 10 V Z . In addition to these basic techniques can be used rather than more complex hybrid functions, the differential X and Y inputs provide significant approaches. operating flexibility both for algebraic computation and transducer 4. High impedance X and Y inputs with negligible circuit instrumentation applications. Transfer functions, such as XY/10 V, loading. (X2 − Y2)/10 V, ±X2/10 V, and 10 V Z/(X 5. Differential X and Y inputs for noise rejection and additional 1 − X2), are easily attained and are extremely useful in many modulation and function computational flexibility. generation applications, as well as in trigonometric calculations for airborne navigation and guidance applications, where the monolithic construction and small size of the AD532 offer considerable system advantages. In addition, the high common- mode rejection ratio (CMRR) (75 dB) of the differential inputs makes the AD532 especially well qualified for instrumentation applications, as it can provide an output signal that is the product of two transducer generated input signals.
Rev. E Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2001–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Flexibility of Operation Functional Block Diagram Guaranteed Performance Over Temperature Advantages of On The Chip Trimming of The Monolithic AD532 Revision History Specifications Thermal Resistance Chip Dimensions And Bonding Diagram ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Functional Description AD532 Performance Characteristics Nonlinearity AC Feedthrough Common-Mode Rejection Dynamic Characteristics Power Supply Considerations Noise Characteristics Applications Replacing Other IC Multipliers Multiplication Squaring Division Square Root Additional Information Outline Dimensions Ordering Guide
