Datasheet AD532 (Analog Devices) - 7
Description | Internally Trimmed Integrated Circuit Multiplier |
Pages / Page | 14 / 7 — Data Sheet. AD532. TYPICAL PERFORMANCE CHARACTERISTICS. Y COMMON-MODE … |
Revision | E |
File Format / Size | PDF / 348 Kb |
Data Sheet. AD532. TYPICAL PERFORMANCE CHARACTERISTICS. Y COMMON-MODE REJ. 1 – X2) = +10V. ) % (. XIN. YIN. X COMMON-MODE REJ. TION 0.1
Data Sheet AD532 TYPICAL PERFORMANCE CHARACTERISTICS 1 70 60 Y COMMON-MODE REJ (X 50 1 – X2) = +10V ) % ( XIN YIN B) 40 d X COMMON-MODE REJ TION 0.1 (Y1 – Y2) = +10V RR ( TOR 30 CM IS D 20 10 0.01 0 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14
005
100 1k 10k 100k 1M 10M
008
PEAK SIGNAL AMPLITUDE (V) FREQUENCY (Hz)
00502- 00502- Figure 5. Distortion vs. Peak Signal Amplitude Figure 8. CMRR vs. Frequency
100 1 20V p-p SIGNAL RL = 2kΩ, CL = 1000pF 10 E (V) D R U L = 2kΩ, CL = 0pF 0.1 IT MPL A 1 DISTORTION (%) XIN YIN 0.1 0.01 10 100 1k 10k 100k 1M 10k 100k 1M 10M
009
FREQUENCY (Hz)
00502-006
FREQUENCY (Hz)
00502- Figure 6. Distortion vs. Frequency Figure 9. Frequency Response, Multiplying
1k 10 VZ = 0.1 × VX sin ωT ) Y FEEDTHROUGH 100 mV H ( E (V) UG D U 1 IT HRO V DT MPL X = 10V E A 10 X FEEDTHROUGH E F VX = 1V VX = 5V 1 0.1 100 1k 10k 100k 1M 10M
007
10k 100k 1M 10M
010
FREQUENCY (Hz) FREQUENCY (Hz)
00502- 00502- Figure 7. Feedthrough vs. Frequency Figure 10. Frequency Response, Dividing Rev. E | Page 7 of 14 Document Outline Features Applications General Description Flexibility of Operation Functional Block Diagram Guaranteed Performance Over Temperature Advantages of On The Chip Trimming of The Monolithic AD532 Revision History Specifications Thermal Resistance Chip Dimensions And Bonding Diagram ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Functional Description AD532 Performance Characteristics Nonlinearity AC Feedthrough Common-Mode Rejection Dynamic Characteristics Power Supply Considerations Noise Characteristics Applications Replacing Other IC Multipliers Multiplication Squaring Division Square Root Additional Information Outline Dimensions Ordering Guide
