Datasheet AD532 (Analog Devices) - 9
DescriptionInternally Trimmed Integrated Circuit Multiplier
Pages / Page14 / 9 — Data Sheet. AD532. FUNCTIONAL DESCRIPTION. +VS. R16. R23. R27. Q7 Q8. Q14 …
RevisionE
File Format / SizePDF / 348 Kb
Data Sheet. AD532. FUNCTIONAL DESCRIPTION. +VS. R16. R23. R27. Q7 Q8. Q14 Q15. Q16 Q17. Q21. R33. Q25. R34. R20. R22. VOS. Q10. R30. R13. R21. R31. Q22 Q26. R28. COM
Data Sheet AD532 FUNCTIONAL DESCRIPTION +VS R16 R23 R27 Q7 Q8 Q14 Q15 Q16 Q17 Q21 R33 Q25 R34 R20 R22 VOS Q10 R30 R13 R21 R31 Q22 Q26 R28 COM
link to page 1 link to page 9
The functional block diagram for the AD532 is shown in Figure 1 The product of the two inputs is resolved in the multiplier cel and the complete schematic in Figure 13. In the multiplying and using Gilbert’s linearized transconductance technique. The cell squaring modes, Z is connected to the output to close the feedback is laser trimmed to obtain VOUT = (X1 − X2)(Y1 − Y2)/10 V. The around the output op amp. In the divide mode, it is used as an built in op amp is used to obtain low output impedance and make input terminal. possible self contained operation. The residual output voltage offset The X and Y inputs are fed to high impedance differential can be zeroed at VOS in critical applications. Otherwise, the VOS pin amplifiers featuring low distortion and good common-mode should be grounded. rejection. The amplifier voltage offsets are actively laser trimmed to zero during production.
X2 +VS R2 R6 R8 R16 R23 R27 Z Q1 Q2 C1 Q7 Q8 Q14 Q15 Q16 Q17 Q21 R33 Q25 R34 R20 R22 R9 VOS Y1 Q9 Q10 R1 R30 X R13 1 Q3 Q4 R21 R31 R3 Q22 Q26 R28 COM OUTPUT R10 Q18 Q23 R29 Q5 Q6 Q11 Q12 Q24 Q27 R19 R32 R11 Q20 R14 Q19 Q28 Q13 R4 R5 R12 R15 R24 R25 R26 –V
004
R18 S CAN Y2
00502- Figure 13. Schematic Diagram Rev. E | Page 9 of 14 Document Outline Features Applications General Description Flexibility of Operation Functional Block Diagram Guaranteed Performance Over Temperature Advantages of On The Chip Trimming of The Monolithic AD532 Revision History Specifications Thermal Resistance Chip Dimensions And Bonding Diagram ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Functional Description AD532 Performance Characteristics Nonlinearity AC Feedthrough Common-Mode Rejection Dynamic Characteristics Power Supply Considerations Noise Characteristics Applications Replacing Other IC Multipliers Multiplication Squaring Division Square Root Additional Information Outline Dimensions Ordering Guide
