Datasheet PE43614 (pSemi) - 6
ManufacturerpSemi
DescriptionUltraCMOS RF Digital Step Attenuator, 9 kHz–45 GHz
Pages / Page23 / 6 — PE43614. UltraCMOS® RF Digital Step Attenuator. Table 3 • PE43614 …
PE43614. UltraCMOS® RF Digital Step Attenuator. Table 3 • PE43614 Electrical Specifications (Cont.). Parameter. Condition. Min. Typ
PE43614 UltraCMOS® RF Digital Step Attenuator Table 3 • PE43614 Electrical Specifications (Cont.) Parameter Condition Min Typ
PE43614 UltraCMOS® RF Digital Step Attenuator Table 3 • PE43614 Electrical Specifications (Cont.) Parameter Condition Min Typ Max Unit
Input IP2 18 dBm tone @ 13 GHz 95.00 dBm Input IP3 18 dBm per tone, 20 MHz spacing @ 13 GHz 50.00 dBm Input 1dB Compression Pt. Bi-directional 32.00 34.00 dBm Input 0.1dB Compres- sion Pt. Bi-directional 25.00 28.00 dBm RF Rise and Fal Time 10%/90% RF 250.00 ns Settling Time RF settled to within 0.05 dB of final value 500.00 ns Switching Time 50% CTRL to 90% or 10% RF 330.00 430.00 ns Attenuation Transient Any state change -7.50 dB Page 6 of 23 DOC-93670-2 – (06/2020) www.psemi.com Document Outline Features Applications Product Description Optional External VSS Control Absolute Maximum Ratings ESD Precautions Latch-up Immunity Recommended Operating Conditions Electrical Specifications Switching Frequency Spur-free Performance Glitch-safe Attenuation State The PE43614 features a novel architecture to provide safe transition behavior when changing attenuation states. When RF input power is applied, positive output power spikes are prevented during attenuation state changes by optimized internal timing c... Truth Tables Serial Addressable Register Map Programming Options Parallel/Serial Selection Parallel Mode Interface For direct parallel programming, the LE line should be pulled HIGH. Changing attenuation state control values changes the device state to new attenuation. Direct mode is ideal for manual control of the device (using hardwire, switches, or jumpers). Serial-Addressable Interface Power-up Control Settings Typical Performance Data Pin Configuration Packaging Information Moisture Sensitivity Level Package Drawing Top-Marking Specification Tape and Reel Specification Ordering Information
