Datasheet PAD (Linear Systems) - 2
ManufacturerLinear Systems
DescriptionPico Ampere Diodes
Pages / Page2 / 2 — Figure 1. Operational Amplifier Protection. Figure 2. Sample and Hold …
File Format / SizePDF / 184 Kb
Figure 1. Operational Amplifier Protection. Figure 2. Sample and Hold Circuit. FIGURE 2. FIGURE 1. TO-72. SOT-23
Figure 1 Operational Amplifier Protection Figure 2 Sample and Hold Circuit FIGURE 2 FIGURE 1 TO-72 SOT-23
Input Differential Voltage limited to 0.8V (typ) by JPADs D1 and D2. Common Mode Input voltage limited by JPADs D3 and D4 to ±15V.
Typical Sample and Hold circuit with clipping. JPAD diodes reduce offset voltages fed capacitively from the JFET switch gate.
FIGURE 2 FIGURE 1
+V -V +V JPAD5 JPAD20 D1 D2 - 2N4117A D1 D2 OP-27 + 2N4393 D3 D4 ein CONTROL SIGNAL C R VOUT +15V -15V
TO-72 SOT-23
Three Lead 0.89 1.03 0.37 1 0.51 1.78 2.80 2.05 3 3.04 2 1.20 1.40 0.89 2.10 1.12 2.64 0.085 0.180 0.013 0.55 0.100 DIMENSIONS IN MILLIMETERS 1. Absolute maximum ratings are limiting values above which serviceability may be impaired. 2. The PAD type number denotes its maximum reverse current value in pico amperes. Devices with IR values intermediate to those shown are available upon request. Information furnished by Linear Integrated Systems is believed to be accurate and reliable. However, no responsibility is assumed for its use; nor for any infringement of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Linear Integrated Systems. Linear Integrated Systems (LIS) is a 25-year-old, third-generation precision semiconductor company providing high-quality discrete components. Expertise brought to LIS is based on processes and products developed at Amelco, Union Carbide, Intersil and Micro Power Systems by company President John H. Hall. Hall, a protégé of Silicon Valley legend Dr. Jean Hoerni, was the director of IC Development at Union Carbide, co-founder and vice president of R&D at Intersil, and founder/president of Micro Power Systems. Linear Integrated Systems • 4042 Clipper Court • Fremont, CA 94538 • Tel: 510 490-9160 • Fax: 510 353-0261 Doc 201142 03/03/2020 Rev#A7 ECN# PAD SERIES
