Datasheet AMP02 (Analog Devices) - 7 Manufacturer Analog Devices Description High Accuracy Instrumentation Amplifier Pages / Page 12 / 7 — AMP02. 120. A = 25. TA = 25. S =. 15V. VS =. 100. L = 1k. OUT = 20mA p-p. … Revision E File Format / Size PDF / 225 Kb Document Language English
AMP02. 120. A = 25. TA = 25. S =. 15V. VS =. 100. L = 1k. OUT = 20mA p-p. – V. A T. ANCE –. -PEAK AMPLITUDE –. OUTPUT V. OUTPUT IMPED. PEAK-. –20. 10k. 100k
Model Line for this Datasheet Text Version of Document AMP02 30 16 120 T T A = 25 ⴗC TA = 25 ⴗC A = 25 ⴗC V V S = ⴞ15V VS = ⴞ15V S = ⴞ15V V 14 100 25 R I L = 1k ⍀OUT = 20mA p-p 12 ⍀– V 80 20 GE 10 A T ANCE – 60 L 15 O 8 40 -PEAK AMPLITUDE – 6 O 10 T OUTPUT V 20 4 OUTPUT IMPED PEAK- 5 2 0 0 0 –20 100 1k 10k 100k 1M 10 100 1k 10k 100k 100 1k 10k 100k 1M 10M FREQUENCY – Hz LOAD RESISTANCE – ⍀FREQUENCY – Hz TPC 19. Maximum Output Swing TPC 20. Maximum Output Voltage TPC 21. Closed Loop Output vs. Frequency vs. Load Resistance Impedance vs. Frequency8 8 VS = ⴞ15V 7 7 TA = –40 ⴗC, +25 ⴗC, +85 ⴗC s 6 6 V T 5 A = –25 ⴗC, +25 ⴗC, +85 ⴗC TE – 5 4 Y CURRENT – mA 4 SLEW RA 3 SUPPL 3 2 1 1 0 ⴞ5 ⴞ10 ⴞ15 ⴞ20 1 10 100 1k SUPPLY VOLTAGE – V VOLTAGE GAIN – G TPC 22. Supply Current TPC 23. Slew Rate vs. vs. Supply Voltage Voltage Gain REV. E –7– Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE WAFER TEST LIMITS Typical Performance Characteristics APPLICATIONS INFORMATION Input and Output Offset Voltages Input Bias and Offset Currents Gain Common-Mode Rejection Grounding Sense and Reference Terminals Overvoltage Protection Power Supply Considerations OUTLINE DIMENSIONS Revision History
