Datasheet AMP01 (Analog Devices) - 2
DescriptionLow-Noise Precision Instrumentation Amp
Pages / Page5 / 2 — Supply. Voltage. (VS). ... ±18V. dc. Common. Mode. Input. Voltage. ... …
File Format / SizePDF / 618 Kb
Supply. Voltage. (VS). ... ±18V. dc. Common. Mode. Input. Voltage. ... Supply. Voltage. Differential. Input. Voltage:. RG. . 2k. .. ±20V. dc. RG. . 2k. .. ±10V. dc. Output
Supply Voltage (VS) .. ±18V dc Common Mode Input Voltage .. Supply Voltage Differential Input Voltage: RG  2k . ±20V dc RG  2k . ±10V dc Output
Supply Voltage (VS) ... ±18V dc Common Mode Input Voltage ... Supply Voltage Differential Input Voltage: RG  2k .. ±20V dc RG  2k .. ±10V dc Output Short Circuit Duration .. Indefinite Storage Temperature Range .. -65C to +150C Ambient Operating Temperature Range ... -55C to +125C Junction Temperature (TJ)... ... +150°C Absolute Maximum Ratings Notes: 1/ Stresses above the absolute maximum rating may cause permanent damage to the device. Extended operation at the maximum levels may degrade performance and affect reliability. In accordance with class-K version of MIL-PRF-38534, Appendix C, Table C-II, except as modified herein. (a) Qual Samples Size and Qual Acceptance Criteria – 25/2 (b) Qual Sample Package – DIP (c) Pre-screen electrical test over temperature performed post-assembly prior to die qualification.
