Datasheet AD524 (Analog Devices) - 8
DescriptionPrecision Instrumentation Amplifier
Pages / Page25 / 8 — AD524. Data Sheet. ABSOLUTE MAXIMUM RATINGS. CONNECTION DIAGRAMS. Table …
RevisionG
File Format / SizePDF / 590 Kb
AD524. Data Sheet. ABSOLUTE MAXIMUM RATINGS. CONNECTION DIAGRAMS. Table 3. Parameter Rating – INPUT 1. 16 RG1. + INPUT 2
AD524 Data Sheet ABSOLUTE MAXIMUM RATINGS CONNECTION DIAGRAMS Table 3 Parameter Rating – INPUT 1 16 RG1 + INPUT 2
AD524 Data Sheet ABSOLUTE MAXIMUM RATINGS CONNECTION DIAGRAMS Table 3. Parameter Rating – INPUT 1 16 RG1
Supply Voltage ±18 V
+ INPUT 2 15 OUTPUT NULL
Internal Power Dissipation 450 mW
RG2 3 14 OUTPUT NULL
Input Voltage1
INPUT NULL 4 AD524 13 G = 10 SHORT TO TOP VIEW RG
(Either Input Simultaneously) |V
INPUT NULL 5 12 G = 100 2 FOR
IN| + |VS| <36 V
(Not to Scale) DESIRED
Output Short-Circuit Duration Indefinite
REFERENCE 6 11 G = 1000 GAIN –V
Storage Temperature Range
S 7 10 SENSE +V
(R) –65°C to +125°C
S 8 9 OUTPUT
(D, E) –65°C to +150°C
4 15
Operating Temperature Range
+V –V S S INPUT 5 14
003 AD524A/AD524B/AD524C –25°C to +85°C
OUTPUT OFFSET NULL OFFSET NULL
500- 0 0 AD524S –55°C to +125°C Figure 3. Ceramic (D) and Lead Temperature (Soldering, 60 sec) +300°C SOIC (RW-16 and D-16) Packages 1 Maximum input voltage specification refers to maximum voltage to which either input terminal may be raised with or without device power applied.
T T
For example, with ±18 volt supplies maximum, V
UT
IN is ±18 V; with zero supply
U PU L P 1 T
voltage maximum, V
N
IN is ±36 V.
INP + –I NC RG OU NUL
Stresses at or above those listed under Absolute Maximum
3 2 1 20 19
Ratings may cause permanent damage to the product. This is a
RG 4 2 18 OUTPUT NULL
stress rating only; functional operation of the product at these
INPUT NULL 5 17 G = 10 AD524 SHORT TO
or any other conditions above those indicated in the operational
NC 6 16 NC RG2 FOR TOP VIEW INPUT NULL 7 (Not to Scale) 15 G = 100 DESIRED
section of this specification is not implied. Operation beyond
GAIN REFERENCE 8 14 G = 1000
the maximum operating conditions for extended periods may affect product reliability.
9 10 11 12 13 NC = NO CONNECT S S T E OUTPUT NC U S SENSE –V +V G = 10 NULL G = 100 G = 1000 10 TP 13 14 12 11 SEN OU OUTPUT NULL 9 7 19 15 OUTPUT +VS –VS INPUT 5 18 OUTPUT
004
RG 8 +V 1 16 S OFFSET NULL OFFSET NULL
0500- 0
0.103
Figure 4. Leadless Chip Carrier (E)
–INPUT (2.61) 1 +INPUT2 7 –VS ESD CAUTION RG23 4 5 6 INPUT INPUT REFERENCE NULL NULL 0.170 (4.33)
02
PAD NUMBERS CORRESPOND TO PIN NUMBERS FOR
-0
THE D-16 AND RW-16 16-LEAD CERAMIC PACKAGES.
500 00 Figure 2. Metallization Photograph Contact factory for latest dimensions; Dimensions shown in inches and (mm) Rev. G | Page 8 of 25 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS CONNECTION DIAGRAMS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION INPUT PROTECTION INPUT OFFSET AND OUTPUT OFFSET GAIN INPUT BIAS CURRENTS COMMON-MODE REJECTION GROUNDING SENSE TERMINAL REFERENCE TERMINAL PROGRAMMABLE GAIN AUTO-ZERO CIRCUITS ERROR BUDGET ANALYSIS REFERENCES OUTLINE DIMENSIONS ORDERING GUIDE
