25 /10 — AD524. Data Sheet. –140. G = 1000. G = 100. –120. A) 12. G = 10. n ±. …
Revision
G
PDF / 590 Kb
AD524. Data Sheet. –140. G = 1000. G = 100. –120. A) 12. G = 10. n ±. –100. ( NT 10. G = 1. –80. CURRE. RR (. –60. BI UT. –40. INP. –20. 100. 10k. 100k. 10M
AD524Data Sheet16–140G = 1000G = 10014–120A) 12G = 10n ±–100( NT 10G = 1B)–80d8CURRERR (–60ASCM6BI UT–404INP–202 014 011 00500- 0 00500- 0051015200101001k10k100k1M10MINPUT VOLTAGE (±V)FREQUENCY (Hz) Figure 11. Input Bias Current vs. Input Voltage Figure 14. CMRR vs. Frequency, RTI, Zero to 1000 Source Imbalance 300)) V-pG = 1, 10, 100µ 1( E LU20SE (V pA 2NL V A 3ESPOFINR EROM 4W 10FRPO5V OSL LΔU FBANDWIDTH LIMITED6 012 015 G = 1000G = 100G = 10 00500- 0 00500- 0123456781k10k100k1MWARM-UP TIME (Minutes)FREQUENCY (Hz) Figure 12. Offset Voltage, RTI, Turn-On Drift Figure 15. Large Signal Frequency Response 1081000) s µV)1006E (V/(V/TINAA10RG4EW SL1G = 10002 013 016 00500- 0 00500- 0101001k10k100k1M10M1101001000FREQUENCY (Hz)GAIN (V/V) Figure 13. Gain vs. Frequency Figure 16. Slew Rate vs. Gain Rev. G | Page 10 of 25 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS CONNECTION DIAGRAMS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION INPUT PROTECTION INPUT OFFSET AND OUTPUT OFFSET GAIN INPUT BIAS CURRENTS COMMON-MODE REJECTION GROUNDING SENSE TERMINAL REFERENCE TERMINAL PROGRAMMABLE GAIN AUTO-ZERO CIRCUITS ERROR BUDGET ANALYSIS REFERENCES OUTLINE DIMENSIONS ORDERING GUIDE
