Datasheet AOZ5311UQI (Alpha & Omega) - 5
ManufacturerAlpha & Omega
DescriptionHigh-Current, High-Performance DrMOS Power Module
Pages / Page18 / 5 — AOZ5311UQI. Absolute Maximum Ratings. Recommended Operating Conditions. …
AOZ5311UQI. Absolute Maximum Ratings. Recommended Operating Conditions. Parameter. Rating. Notes:. www.aosmd.com
AOZ5311UQI Absolute Maximum Ratings Recommended Operating Conditions Parameter Rating Notes: www.aosmd.com
Exceeding the Absolute Maximum ratings may damage The device is not guaranteed to operate beyond the the device. Maximum Recommended Operating Conditions.
Parameter Rating Parameter Rating
Low Voltage Supply (VCC, PVCC) -0.3V to 7V High Voltage Supply (VIN) 2.5V to 20V High Voltage Supply (VIN) -0.3V to 25V Low Voltage / MOSFET Driver Supply 4.5V to 5.5V Control Inputs (VCC, PVCC) (PWM, SMOD#, DISB#) -0.3V to (VCC+0.3V) Control Inputs Output (THWN) -0.3V to (VCC+0.3V) (PWM, SMOD#, DISB#) 0V to VCC Bootstrap Voltage DC Output (THWN) 0V to VCC (BOOT-PGND) -0.3V to 28V Operating Frequency 200kHz to 2MHz Bootstrap Voltage Transient(1) (BOOT-PGND) -8V to 30V Bootstrap Voltage DC (BOOT-PHASE/VSWH) -0.3V to 7V BOOT Voltage Transient(1) (BOOT-PHASE/VSWH) -0.3V to 9V Switch Node Voltage DC (PHASE/VSWH) -0.3V to 25V Switch Node Voltage Transient(1) (PHASE/VSWH) -8V to 33V Low-Side Gate Voltage DC (GL) (PGND-0.3V) to (PVCC+0.3V) Low-Side Gate Voltage Tran- (PGND-2.5V) to sient(1) (GL) (PVCC+0.3V) VSWH Current DC 50A VSWH Current 10ms Pulse 80A VSWH Current 10us Pulse 120A Storage Temperature (TS) -65°C to 150°C Max Junction Temperature (TJ) 150°C ESD Rating(3) 2kV
Notes:
1. Peak voltages can be applied for 10ns per switching cycle. 2..Peak voltages can be applied for 20ns per switching cycle. 3. Devices are inherently ESD sensitive, handling precautions are required. Human body model rating: 1.5 in series with 100pF. Rev. 1.0 June 2019
www.aosmd.com
Page 5 of 18
