Datasheet MCP47FXBX4/8 (Microchip) - 8
ManufacturerMicrochip
Description8/10/12-Bit Quad/Octal Voltage Output, 6 LSb INL Digital-to-Analog Converters with I²C Interface
Pages / Page124 / 8 — MCP47FXBX4/8. DC CHARACTERISTICS (CONTINUED). Standard Operating …
File Format / SizePDF / 9.8 Mb
MCP47FXBX4/8. DC CHARACTERISTICS (CONTINUED). Standard Operating Conditions (unless otherwise specified)
MCP47FXBX4/8 DC CHARACTERISTICS (CONTINUED) Standard Operating Conditions (unless otherwise specified)
MCP47FXBX4/8
Operating Temperature: -40°C  TA  +125°C (Extended)
All parameters apply across the specified operating ranges unless noted.
VDD = +2.7V to 5.5V, VREF= +2.048V to VDD, VSS = 0V, Gx = 0, RL = 5 k from VOUT to GND, CL = 100 pF.
Typical specifications represent values for VDD = 5.5V, TA = +25°C.
Parameters Sym. Min. Typ. Max. Units Resistor Ladder
Resistance RL 100 140 180 k Resolution
(# of Resistors and # of
Taps)
(see C.1 “Resolution”) N Nominal VOUT Match(11) |VOUT -VOUTMEAN|
/VOUTMEAN — 0.5 1.0 % 2.7V  VDD  5.5V(2) — — 1.2 % 1.8V(2) VOUT/T — 15 — VREF VSS — VDD VOUT Temperature
Coefficient (see C.19
“VOUT Temperature
Coefficient”)
VREF Pin Input Voltage
Range Conditions
VRnB:VRnA = 10
VREF = VDD(6) 256 Taps 8-bit No missing codes 1024 Taps 10-bit No missing codes 4096 Taps 12-bit No missing codes ppm/°C Code = Midscale
(7Fh, 1FFh or 7FFh) V 1.8V  VDD  5.5V(1) Note 1 This parameter is ensured by design. Note 2 This parameter is ensured by characterization. Note 6 Resistance is defined as the resistance between the VREF pin (mode VRnB:VRnA = 10) to VSS pin. For
octal-channel devices (MCP47FXBX8), this is the effective resistance of each resistor ladder. The
resistance measurement is one of the two resistor ladders measured in parallel. Note 11 Variation of one output voltage to mean output voltage. DS20006368A-page 8  2020 Microchip Technology Inc.
