Datasheet CBRDFA4-100 (Central Semiconductor)
DescriptionSurface Mount Silicon 4 Amp Bridge Rectifier
Pages / Page6 / 1 — CBRDFA4-100. w w w. c e n t r a l s e m i . c o m. SURFACE MOUNT SILICON. …
File Format / SizePDF / 765 Kb
CBRDFA4-100. w w w. c e n t r a l s e m i . c o m. SURFACE MOUNT SILICON. DESCRIPTION:. 4 AMP BRIDGE RECTIFIER
Datasheet CBRDFA4-100 Central Semiconductor
CBRDFA4-100 w w w. c e n t r a l s e m i . c o m SURFACE MOUNT SILICON DESCRIPTION: 4 AMP BRIDGE RECTIFIER
The CENTRAL SEMICONDUCTOR CBRDFA4-100 is a full wave bridge rectifier mounted in a durable epoxy surface mount case, utilizing glass passivated chips.
MARKING CODE: BR4100 FEATURES:
High 4.0A Current Rating
Low VF Diodes (1.0V MAX @ IF=4.0A)
BR DFN-A CASE MAXIMUM RATINGS:
(TA=25°C unless otherwise noted)
SYMBOL UNITS
Peak Repetitive Reverse Voltage VRRM 1000 V DC Blocking Voltage VR 1000 V Average Forward Current (TC=112°C) IO 4.0 A Peak Forward Surge Current (8.3ms) IFSM 150 A Operating and Storage Junction Temperature TJ, Tstg -55 to +175 °C
ELECTRICAL CHARACTERISTICS PER DIODE:
SYMBOL TEST CONDITIONS TYP MAX UNITS
IR VR=1000V 5.0 µA VF IF=4.0A 0.95 1.0 V CJ VR=4.0V, f=1.0MHz 45 pF R2 (23-June 2020)
