Datasheet LTC4162-S (Analog Devices) - 3
Description35V/3.2A Lead-Acid Step-Down Battery Charger with PowerPath and I2C Telemetry
Pages / Page48 / 3 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. PART NUMBER. PART. TAPE AND. TEMP. MARKING*. REEL. GRADE
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION PART NUMBER PART TAPE AND TEMP MARKING* REEL GRADE
LTC4162-S
BATSENS+, V TOP VIEW IN, CSP, CSN, CLP, CLN, VOUT, VOUTA .. −0.3V to 36V CSP to CSN, CLP to CLN ..±0.3V V OUT V OUT SW SW PGND PGND 28 27 26 25 24 23 CELLSO, CELLS1, SYNC ... −0.3V to INTVCC BOOST 1 22 BATFET DVCC ... −0.3V to 5.5V INTVCC 2 21 CSP SDA, SCL, SMBALERT ... −0.3V to DVCC VOUTA 3 20 CSN ISW ... ±3.5A CLN 4 19 BATSENS+ AGND Operating Junction Temperature Range CLP 5 29 18 CELLS1 (Notes 2, 4) .. −40 to 125°C INFET 6 17 CELLS0 Storage Temperature Range ..−65 to 150°C VIN 7 16 SYNC VCC2P5 8 15 DVCC 9 10 11 12 13 14 R T NTC SCL SDA NTCBIAS SMBALERT UFD PACKAGE 28-LEAD (4mm × 5mm) PLASTIC QFN TJMAX = 125°C, θJA = 43°C/W, θJC = 3.4°C/W EXPOSED PAD (PIN 29) IS GND, MUST BE SOLDERED TO PCB
ORDER INFORMATION PART NUMBER PART TAPE AND TEMP MARKING* REEL GRADE DESCRIPTION TEMPERATURE RANGE
LTC4162EUFD-SAD#PBF 4162H E I2C Adjustable Voltage –40°C to 125°C LTC4162EUFD-SST#PBF 4162J E Fixed Voltage –40°C to 125°C LTC4162EUFD-SADM#PBF 4162T E I2C Adjustable Voltage MPPT ON –40°C to 125°C LTC4162EUFD-SSTM#PBF 4162U E Fixed Voltage MPPT ON –40°C to 125°C LTC4162EUFD-SAD#TRPBF 4162H ✓ E I2C Adjustable Voltage –40°C to 125°C LTC4162EUFD-SST#TRPBF 4162J ✓ E Fixed Voltage –40°C to 125°C LTC4162EUFD-SADM#TRPBF 4162T ✓ E I2C Adjustable Voltage MPPT ON –40°C to 125°C LTC4162EUFD-SSTM#TRPBF 4162U ✓ E Fixed Voltage MPPT ON –40°C to 125°C LTC4162IUFD-SAD#PBF 4162H I I2C Adjustable Voltage –40°C to 125°C LTC4162IUFD-SST#PBF 4162J I Fixed Voltage –40°C to 125°C LTC4162IUFD-SADM#PBF 4162T I I2C Adjustable Voltage MPPT ON –40°C to 125°C LTC4162IUFD-SSTM#PBF 4162U I Fixed Voltage MPPT ON –40°C to 125°C LTC4162IUFD-SAD#TRPBF 4162H ✓ I I2C Adjustable Voltage –40°C to 125°C LTC4162IUFD-SST#TRPBF 4162J ✓ I Fixed Voltage –40°C to 125°C LTC4162IUFD-SADM#TRPBF 4162T ✓ I I2C Adjustable Voltage MPPT ON –40°C to 125°C LTC4162IUFD-SSTM#TRPBF 4162U ✓ I Fixed Voltage MPPT ON –40°C to 125°C Contact the factory for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Tape and reel specifications. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. Rev B For more information www.analog.com 3 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram ESD Diagram Timing Diagram Operation Applications Information Register Descriptions Typical Applications Package Description Revision History Typical Application Related Parts
