Datasheet LTC6226, LTC6227 (Analog Devices) - 9
Description1nV/√Hz 420MHz GBW, 180V/µs, Low Distortion Rail-to-Rail Output Op Amps
Pages / Page28 / 9 — ELECTRICAL CHARACTERISTICS (V. The. denotes the specifications which …
File Format / SizePDF / 2.3 Mb
ELECTRICAL CHARACTERISTICS (V. The. denotes the specifications which apply. S = 3V, 0V)
ELECTRICAL CHARACTERISTICS (V The denotes the specifications which apply S = 3V, 0V)
link to page 2 LTC6226/LTC6227
denotes the specifications which apply S = 3V, 0V) over the full operating temperature range, otherwise specifications are at TA = 25°C. VS = 3V, 0V,VCM = 1.5V, VSHDN = floating unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
HD2/HD3 Harmonic Distortion, RL = 1kΩ to VCM, fC = 100kHz –122/–137 dBc VOUT = 1VP-P, VCM = 1V fC = 1MHz –108/–111 dBc fC = 2MHz –95/–95 dBc Harmonic Distortion, RL = 100Ω to VCM, fC = 100kHz –113/–130 dBc VOUT = 1VP-P, VCM = 1V fC = 1MHz –100/–94 dBc fC = 2MHz –90/–79 dBc
Note 1:
Note 5:
Matching parameters are the difference between amplifiers A and may cause permanent damage to the device. Exposure to any Absolute B on the LTC6227. Maximum Rating condition for extended periods may affect device
Note 6:
The input bias current is the average of the average of the currents reliability and lifetime. through the positive and negative input pins.
Note 2:
The inputs are protected by back-to-back diodes. If any of
Note 7:
Supply Voltage Range is guaranteed by Power Supply Rejection the input or shutdown pins goes 300mV beyond either supply or the Ratio test. differential input voltage exceeds 0.7V, the input current should be limited
Note 8:
Thermal resistance varies with the amount of PC board metal to less than 10mA. connected to the package. The specified values are with short traces
Note 3:
A heat sink may be required to keep the junction temperature connected to the leads. below the absolute maximum rating when the output current is high.
Note 9:
Middle 2/3 of the output waveform is observed for Slew Rate.
Note 4:
The LTC6226I/LTC6227I are guaranteed functional and specified RL = 1k to half supply. over the temperature range of –40°C to 85°C. The LTC6226H/LTC6227H
Note 10:
Input Common Mode Range is guaranteed by Common Mode are guaranteed and specified functional over the temperature range of Rejection Ratio Test. –40°C to 125°C.
TYPICAL PERFORMANCE CHARACTERISTICS VS = ±5V, VCM = 0V, RL = 1kΩ to Half Supply, TA = 25°C, unless otherwise noted. Offset Distribution Offset Distribution Offset Distribution
50 50 50 VS = ±5V V V 45 S = 5V, 0V S = 3V, 0V V 45 45 CM = 0V VCM = 2.5V VCM = 1.5V 40 TA = 25°C T 40 A = 25°C T 40 A = 25°C 300 UNITS 300 UNITS 300 UNITS 35 35 35 30 30 30 25 25 25 20 20 20 15 15 15 PERCENT OF UNITS (%) PERCENT OF UNITS (%) PERCENT OF UNITS (%) 10 10 10 5 5 5 0 0 0 –50 –40 –30 –20 –10 0 10 20 30 40 50 –50 –40 –30 –20 –10 0 10 20 30 40 50 –50 –40 –30 –20 –10 0 10 20 30 40 50 INPUT OFFSET VOLTAGE (µV) INPUT OFFSET VOLTAGE (µV) INPUT OFFSET VOLTAGE (µV) 62267 G01 62267 G02 62267 G03 Rev 0 For more information www.analog.com 9 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics (VS = ±5V) Electrical Characteristics (VS = 5V, 0V) Electrical Characteristics (VS = 3V, 0V) Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Typical Application Related Parts
