Datasheet LTC6226, LTC6227 (Analog Devices) - 10
Description1nV/√Hz 420MHz GBW, 180V/µs, Low Distortion Rail-to-Rail Output Op Amps
Pages / Page28 / 10 — TYPICAL PERFORMANCE CHARACTERISTICS. VS = ±5V, VCM = 0V, RL = 1kΩ to Half …
File Format / SizePDF / 2.3 Mb
TYPICAL PERFORMANCE CHARACTERISTICS. VS = ±5V, VCM = 0V, RL = 1kΩ to Half Supply,. TA = 25°C, unless otherwise noted
TYPICAL PERFORMANCE CHARACTERISTICS VS = ±5V, VCM = 0V, RL = 1kΩ to Half Supply, TA = 25°C, unless otherwise noted
LTC6226/LTC6227
TYPICAL PERFORMANCE CHARACTERISTICS VS = ±5V, VCM = 0V, RL = 1kΩ to Half Supply, TA = 25°C, unless otherwise noted. VOS vs Temperature, 10V Supply VOS vs Temperature, 5V Supply VOS vs Temperature, 3V Supply
100 100 100 90 VS = ±5V 90 VS = 5V, 0V 90 VS = 3V, 0V V 80 CM = 0V V 80 CM = 2.5V V 80 CM = 1.5V 5 DEVICES 70 5 DEVICES 5 DEVICES V) 70 V) 70 V) 60 60 60 50 50 50 TAGE (µ 40 TAGE (µ 40 TAGE (µ 40 30 30 30 20 20 20 10 10 10 0 0 0 –10 –10 –10 INPUT OFFSET VOL –20 INPUT OFFSET VOL –20 INPUT OFFSET VOL –20 –30 –30 –30 –40 –40 –40 –50 –50 –50 –55 –35 –15 5 25 45 65 85 105 125 –55 –35 –15 5 25 45 65 85 105 125 –55 –35 –15 5 25 45 65 85 105 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 62267 G04 6227 G05 62267 G06
Offset Voltage vs Input Common Mode Voltage Offset Voltage vs Output Current Warm Up Drift vs Time
100 200 50 V 90 S = ±5V VS = ±5V 180 VS = ±5V 80 TA = 25°C 160 V) 40 70 V) 60 140 T V) A = 125°C 50 120 TAGE (µ 30 40 TAGE (µ TAGE (µ 100 30 20 TA = –55°C TA = 85°C 20 80 10 60 10 OFFSET VOL 0 TA = 25°C OFFSET VOL 40 125°C –10 85°C 20 –20 25°C CHANGE IN OFFSET VOL 0 –30 0 –55°C –40 –20 –10 –6 –5 –4 –3 –2 –1 0 1 2 3 4 5 –30 –24 –18 –12 –6 0 6 12 18 24 30 0 1 2 3 4 5 6 7 8 INPUT COMMON MODE VOLTAGE (V) OUTPUT CURRENT (mA) TIME AFTER POWER UP (ms) 62267 G07 62267 G08 62267 G09
Input Noise Voltage and Noise Input Bias Current vs Current Spectral Densities Input Common Mode Voltage 0.1Hz to 10Hz Voltage Noise vs Frequency
–5 500.0 2k V V 1k S = ±5V S = ±5V 400.0 T T A = –55°C A = 25°C –8 300.0 TA = 25°C /√Hz) 200.0 100 TA = 85°C –11 100.0 TAGE (nV 0 TAGE NOISE ( nV) 10 –14 –100.0 T i A = 125°C N, –200.0 INPUT BIAS CURRENT (µA) eN 1 –17 INPUT VOL –300.0 INPUT NOISE VOL INPUT NOISE CURRENT (pA/√Hz) –400.0 –20 –500.0 0.1 –5.1 –4.1 –3.1 –2.1 –1.1 –0.2 0.8 1.8 2.8 3.8 1s/DIV 62267 G11 0.1 1 10 100 1k 10k 100k 1M 10M100M INPUT COMMON MODE VOLTAGE (V) FREQUENCY (Hz) 62267 G10 62267 G12 Rev 0 10 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics (VS = ±5V) Electrical Characteristics (VS = 5V, 0V) Electrical Characteristics (VS = 3V, 0V) Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Typical Application Related Parts
