Datasheet LTC6228, LTC6229 (Analog Devices) - 10
Description0.88nV/√Hz 730MHz, 500V/µs, Low Distortion Rail-to-Rail Output Op Amps with Shutdown
Pages / Page30 / 10 — TYPICAL PERFORMANCE CHARACTERISTICS. VS = ±5V, VCM = 0V, TA = 25°C, …
RevisionB
File Format / SizePDF / 2.6 Mb
TYPICAL PERFORMANCE CHARACTERISTICS. VS = ±5V, VCM = 0V, TA = 25°C, unless otherwise noted. Offset Distribution
TYPICAL PERFORMANCE CHARACTERISTICS VS = ±5V, VCM = 0V, TA = 25°C, unless otherwise noted Offset Distribution
LTC6228/LTC6229
TYPICAL PERFORMANCE CHARACTERISTICS VS = ±5V, VCM = 0V, TA = 25°C, unless otherwise noted. Offset Distribution Offset Distribution Offset Distribution
50 50 50 VS = ±5V V V 45 S = 5V, 0V S = 3V, 0V VCM = 0V 45 V 45 CM = 2.5V VCM = 1.5V TA = 25°C 40 40 TA = 25°C 40 TA = 25°C 35 35 35 30 30 30 25 25 25 20 20 20 15 15 PERCENT OF UNITS (%) 15 PERCENT OF UNITS (%) PERCENT OF UNITS (%) 10 10 10 5 5 5 0 0 0 –60–50–40–30–20–10 0 10 20 30 40 50 60 –60–50–40–30–20–10 0 10 20 30 40 50 60 –60–50–40–30–20–10 0 10 20 30 40 50 60 INPUT OFFSET VOLTAGE (µV) INPUT OFFSET VOLTAGE (µV) INPUT OFFSET VOLTAGE (µV) 6228 G01 6228 G02 6228 G03
VOS vs Temperature, 10V Supply VOS vs Temperature, 5V Supply VOS vs Temperature, 3V Supply
160 160 160 VS = ±5V VS = ±2.5V VS = 3V, 0V 140 VCM = 0V 140 VCM = 0V 140 VCM = 1.5V 5 DEVICES 5 DEVICES 5 DEVICES V) 120 V) 120 V) 120 TAGE (µ 100 TAGE (µ 100 TAGE (µ 100 80 80 80 60 60 60 40 40 40 INPUT OFFSET VOL INPUT OFFSET VOL INPUT OFFSET VOL 20 20 20 0 0 0 –55 –35 –15 5 25 45 65 85 105 125 –55 –35 –15 5 25 45 65 85 105 125 –55 –35 –15 5 25 45 65 85 105 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 6228 G04 6228 G05 6228 G06
Offset Voltage vs Input Common Mode Voltage Offset Voltage vs Output Current Warm Up Drift vs T W ime arm–up Drift vs T
100 200 50 V 90 S = ±5V VS = ±5V 180 VS = ±5V 80 TA=25°C V) 40 70 160 V) 60 T V) A = 125°C 140 50 TAGE (µ 30 40 T 120 A = 85°C TAGE (µ TAGE (µ 30 100 T 20 A = 125°C 20 80 10 10 OFFSET VOL 0 60 OFFSET VOL TA = 85°C –10 TA = –55°C 40 TA = –55°C –20 CHANGE IN OFFSET VOL 0 T –30 A = 25°C 20 TA = 25°C –40 0 –10 –6 –5 –4 –3 –2 –1 0 1 2 3 4 5 –50 –40 –30 –20 –10 0 10 20 30 40 50 0 1 2 3 4 5 6 7 8 INPUT COMMON MODE VOLTAGE (V) OUTPUT CURRENT (mA) TIME AFTER POWER UP (s) 6228 G07 6228 G08 6228 G09 Rev. B 10 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics (VS = ±5V) Electrical Characteristics (VS = 5V, 0V) Electrical Characteristics (VS = 3V, 0V) Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
