Datasheet ADA4610-1, ADA4610-2, ADA4610-4 (Analog Devices)
DescriptionLow Noise, Precision, Rail-to-Rail Output, JFET Single Op Amp
Pages / Page27 / 1 — Low Noise, Precision, Rail-to-Rail Output,. JFET Single/Dual/Quad Op …
RevisionI
Low Noise, Precision, Rail-to-Rail Output,. JFET Single/Dual/Quad Op Amps. Data Sheet. ADA4610-1. /ADA4610-2. /ADA4610-4. FEATURES
Datasheet ADA4610-1, ADA4610-2, ADA4610-4 Analog Devices, Revision: I
link to page 8
Low Noise, Precision, Rail-to-Rail Output, JFET Single/Dual/Quad Op Amps Data Sheet ADA4610-1 /ADA4610-2 /ADA4610-4 FEATURES PIN CONFIGURATION Low offset voltage OUT A 1 8 V+ B grade: 0.4 mV maximum (ADA4610-1/ ADA4610-2 on ly) –IN A ADA4610-2 2 7 OUT B TOP VIEW A grade: 1 mV maximum +IN A 3 6 –IN B (Not to Scale)
002
Low offset voltage drift V– 4 5 +IN B B grade: 2 µV/°C maximum (ADA4610-1/ ADA4610-2 on ly)
09646- Figure 1. ADA4610-2 8-Lead SOIC (R Suffix); for Additional Packages and
A grade: 8 µV/°C maximum (SOIC, MSOP, LFCSP packages)
Models, See the Pin Configurations and Function Descriptions Section
Low input bias current: 5 pA typical Dual-supply operation: ±5 V to ±15 V Low voltage noise: 0.45 µV p-p at 0.1 Hz to 10 Hz Voltage noise density: 7.30 nV/√Hz at f = 1 kHz Low THD + N: 0.00025% No phase reversal Rail-to-rail output Unity-gain stable Long-term offset voltage drift (10,000 hours): 5 µV typical Temperature hysteresis: 8 µV typical APPLICATIONS Instrumentation Medical instruments Multipole filters Precision current measurement Photodiode amplifiers Sensors Audio GENERAL DESCRIPTION
The ADA4610-1/ADA4610-2/ADA4610-4 are precision junction performance filters. Low input bias currents, low offset, and low field effect transistor (JFET) amplifiers that feature low input noise noise result in a wide dynamic range for photodiode amplifier voltage, current noise, offset voltage, input bias current, and rail-to- circuits. Low noise and distortion, high output current, and rail output. The ADA4610-1 is a single amplifier, the ADA4610-2 is excellent speed make the ADA4610-1/ADA4610-2/ ADA4610-4 a dual amplifier, and the ADA4610-4 is a quad amplifier. great choices for audio applications. The combination of low offset, noise, and very low input bias The ADA4610-1/ADA4610-2/ADA4610-4 are specified over current makes these amplifiers especially suitable for high the −40°C to +125°C extended industrial temperature range. impedance sensor amplification and precise current measurements The ADA4610-1 is available in an 8-lead SOIC package and in a using shunts. With excellent dc precision, low noise, and fast 5-lead SOT-23 package. The ADA4610-2 is available in 8-lead settling time, the ADA4610-1/ADA4610-2/ADA4610-4 provide SOIC, 8-lead MSOP, and 8-lead LFCSP packages. The ADA4610-4 superior accuracy in medical instruments, electronic measurement, is available in a 14-lead SOIC package and in a 16-lead LFCSP. and automated test equipment. Unlike many competitive amplifiers, the ADA4610-1/ADA4610-2/ADA4610-4 maintain
Table 1. Related Precision JFET Operational Amplifiers
fast settling performance with substantial capacitive loads. Unlike
Single Dual Quad
many older JFET amplifiers, the ADA4610-1/ADA4610-2/ AD8510 AD8512 AD8513 ADA4610-4 do not suffer from output phase reversal when input AD8610 AD8620 Not applicable voltages exceed the maximum common-mode voltage range. AD820 AD822 AD824 The fast slew rate and great stability with capacitive loads make ADA4627-1/ADA4637-1 Not applicable Not applicable the ADA4610-1/ADA4610-2/ADA4610-4 ideal for high Not applicable ADA4001-2 Not applicable
Rev. I Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2011–2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Comparative Voltage and Variable Voltage Graphs Theory of Operation Applications Information Input Overvoltage Protection Peak Detector Current to Voltage (I to V) Conversion Applications Photodiode Circuits Comparator Operation Long-Term Drift Temperature Hysteresis Outline Dimensions Ordering Guide
