Datasheet ADA4610-1, ADA4610-2, ADA4610-4 (Analog Devices) - 7
DescriptionLow Noise, Precision, Rail-to-Rail Output, JFET Single Op Amp
Pages / Page27 / 7 — Data Sheet. ADA4610-1/ADA4610-2/ADA4610-4. ABSOLUTE MAXIMUM RATINGS Table …
RevisionI
Data Sheet. ADA4610-1/ADA4610-2/ADA4610-4. ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE. Parameter. Rating
Data Sheet ADA4610-1/ADA4610-2/ADA4610-4 ABSOLUTE MAXIMUM RATINGS Table 4 THERMAL RESISTANCE Parameter Rating
Data Sheet ADA4610-1/ADA4610-2/ADA4610-4 ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE Parameter Rating Table 5. Thermal Resistance
Supply Voltage ±18 V
Package Type θ 1 JA θJC Unit
Input Voltage ±VS 5-Lead SOT-23 219.4 155.6 °C/W Input Current1 ±10 mA 8-Lead SOIC 120 43 °C/W Storage Temperature Range −65°C to +150°C 8-Lead LFCSP 57 12 °C/W Operating Temperature Range −40°C to +125°C 8-Lead MSOP 142 45 °C/W Junction Temperature Range −65°C to +150°C 14-Lead SOIC 115 36 °C/W Lead Temperature (Soldering, 10 sec) 300°C 16-Lead LFCSP 65 3.2 °C/W Electrostatic Discharge (ESD) Human Body Model (HBM)2 2500 V 1 θJA is specified for worst-case conditions, that is, θJA is specified for a device Field Induced Charge Device Model (FICDM)3 1250 V soldered in a circuit board for surface-mount packages. 1 The input pins have clamp diodes connected to the power supply pins. Limit the input current to 10 mA or less whenever input signals exceed the power
ESD CAUTION
supply rail by 0.3 V. 2 ESDA/JEDEC JS-001-2011 applicable standard. 3 JESD22-C101 (ESD FICDM standard of JEDEC) applicable standard. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. I | Page 7 of 27 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Comparative Voltage and Variable Voltage Graphs Theory of Operation Applications Information Input Overvoltage Protection Peak Detector Current to Voltage (I to V) Conversion Applications Photodiode Circuits Comparator Operation Long-Term Drift Temperature Hysteresis Outline Dimensions Ordering Guide
