Datasheet ADA4897-2-KGD (Analog Devices) - 9
Description1 nV/√Hz, Low Power Operational Amplifier
Pages / Page10 / 9 — Known Good Die. ADA4897-2-KGD. PIN CONFIGURATION AND FUNCTION …
RevisionC
File Format / SizePDF / 238 Kb
Known Good Die. ADA4897-2-KGD. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. ANALOG DEVICES, INC., LOGO. 10A. TOP VIEW
Known Good Die ADA4897-2-KGD PIN CONFIGURATION AND FUNCTION DESCRIPTIONS ANALOG DEVICES, INC., LOGO 10A TOP VIEW
Known Good Die ADA4897-2-KGD PIN CONFIGURATION AND FUNCTION DESCRIPTIONS ANALOG DEVICES, INC., LOGO 10 10A 1A 1 9 9A 2 8 3 4 7 4A 5 6
001
TOP VIEW
12328-
(CIRCUIT SIDE)
Figure 1. Pad Configuration
Table 5. Pad Function Descriptions Pad No. X-Axis Y-Axis Mnemonic Description
1 −402 +279 OUT1 Output 1 1A −402 +354 OUT1 Output 1, Double Bond Pad 2 −400 −41 −IN1 Inverting Input 1 3 −400 −197 +IN1 Noninverting Input 1 4 −420 −303 −VS Negative Supply 4A −420 −378 −VS Negative Supply, Double Bond Pad 5 −395 −485 DISABLE1 Disable Control 1 6 +395 −485 DISABLE2 Disable Control 2 7 +402 −317 +IN2 Noninverting Input 2 8 +402 −161 −IN2 Inverting Input 2 9 +402 +275 OUT2 Output 2 9A +402 +203 OUT2 Output 2, Double Bond Pad 10 +364 +477 +VS Positive Supply 10A +364 +402 +VS Positive Supply, Double Bond Pad Rev. C | Page 9 of 10 Document Outline Features Applications General Description Revision History Specifications ±5 V Supply +5 V Supply +3 V Supply Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Outline Dimensions Die Specifications and Assembly Recommendations Ordering Guide
