Datasheet ADA4310-1 (Analog Devices) - 4
DescriptionLow Cost, Dual, High Current Output Line Driver with Shutdown
Pages / Page14 / 4 — ADA4310-1. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. …
RevisionC
File Format / SizePDF / 413 Kb
ADA4310-1. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADA4310-1 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
POWER DOWN PINS PD1, PD0 Threshold Referenced to GND 1.5 V PD1, PD0 = 0 Pin Bias Current PD1 or PD0 = 0 V −0.2 µA PD1, PD0 = 1 Pin Bias Current PD1 or PD0 = 3 V 70 µA Enable/Disable Time 0.04/2 µs Power Supply Rejection Ratio Positive/Negative −70/−60 dB Rev. C | Page 4 of 14 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION FEEDBACK RESISTOR SELECTION POWER CONTROL MODES OF OPERATION EXPOSED THERMAL PAD CONNECTIONS POWER LINE APPLICATION BOARD LAYOUT POWER SUPPLY BYPASSING OUTLINE DIMENSIONS ORDERING GUIDE
