Datasheet ADA4310-1 (Analog Devices) - 8
DescriptionLow Cost, Dual, High Current Output Line Driver with Shutdown
Pages / Page14 / 8 — ADA4310-1. Data Sheet. –40. PD1, PD0 = (0, 0). PD1, PD0 = (1,1). RL = …
RevisionC
File Format / SizePDF / 413 Kb
ADA4310-1. Data Sheet. –40. PD1, PD0 = (0, 0). PD1, PD0 = (1,1). RL = 100Ω. –10. B) d ( N. –60. –20. JE –30. H (. UG –80. O –40. E F. M –50. –100. CO –60
ADA4310-1 Data Sheet –40 PD1, PD0 = (0, 0) PD1, PD0 = (1,1) RL = 100Ω –10 B) d ( N –60 –20 JE –30 H ( UG –80 O –40 E F M –50 –100 CO –60
ADA4310-1 Data Sheet 0 –40 PD1, PD0 = (0, 0) PD1, PD0 = (1,1) RL = 100Ω –10 B) d ( N –60 –20 IO B) CT d JE –30 H ( RE UG –80 DE RO O –40 H -M DT N E O E F M –50 M –100 CO –60 –70 –120 0.01 0.1 1 10 100 1000
7
1 10 100 1000
0 -00 01 27 7-
FREQUENCY (MHz)
60
FREQUENCY (MHz)
02 0 06 Figure 13. Common-Mode Rejection(CMR) vs. Frequency Figure 16. Off-Isolation vs. Frequency
0 G = +5 1000 PD1, PD0 = (1,1) PD1, PD0 = (0, 0) –10 R ) L = 100Ω B 100 d –20 N ( ) IO kΩ ( 10 CT –30 E +PSR JE RE –40 DANC Y E 1 L P P –PSR M P I U –50 UT S P R 0.1 E –60 UT W O O P 0.01 –70 –80 0.001 0.01 0.1 1 10 100 1000
06 0
08 7- 0 7-
FREQUENCY (MHz)
02 02 06
FREQUENCY (MHz)
06 Figure 14. Power Supply Rejection(PSR) vs. Frequency Figure 17. Output Impedance vs. Frequency (Disabled)
100 2.5 PD1, PD0 = (0, 0) 10ns/DIV VOUT 2.0 ) 10 Ω ( VPD0, VPD1 CE 1.5 ) DAN V E ( P 1 M GE I 1.0 UT LTA P O UT V O 0.1 0.5 0 0.01
11 0
0.1 1 10 100 1000
9 -00 27 6027-
FREQUENCY (MHz) –0.5
0 60 0 Figure 15. Closed-Loop Output Impedance vs. Frequency Figure 18. Power-Down Turn On/Turn Off Rev. C | Page 8 of 14 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION FEEDBACK RESISTOR SELECTION POWER CONTROL MODES OF OPERATION EXPOSED THERMAL PAD CONNECTIONS POWER LINE APPLICATION BOARD LAYOUT POWER SUPPLY BYPASSING OUTLINE DIMENSIONS ORDERING GUIDE
