Datasheet AD8024 (Analog Devices) - 4
DescriptionQuad 350 MHz 24 V Amplifier
Pages / Page12 / 4 — AD8024–Typical Performance Characteristics. TA = 25. Volts. TOTAL SUPPLY …
RevisionC
File Format / SizePDF / 172 Kb
AD8024–Typical Performance Characteristics. TA = 25. Volts. TOTAL SUPPLY CURRENT. COMMON-MODE VOLTAGE. SUPPLY VOLTAGE –. 7.0. –SWING
AD8024–Typical Performance Characteristics TA = 25 Volts TOTAL SUPPLY CURRENT COMMON-MODE VOLTAGE SUPPLY VOLTAGE – 7.0 –SWING
AD8024–Typical Performance Characteristics 12 25 TA = 25 C TA = 25 C 10 20 Volts mA 8 –V 15 CM 6 +V 10 CM 4 TOTAL SUPPLY CURRENT 5 COMMON-MODE VOLTAGE 2 0 0 2 4 6 8 10 12 0 2 4 6 8 10 12 14 SUPPLY VOLTAGE – Volts SUPPLY VOLTAGE – Volts
TPC 1. Input Common-Mode Voltage Range vs. TPC 4. Total Supply Current vs. Supply Voltage Supply Voltage
7.0 24 V –SWING S = 7.5V 6.5 22 V +SWING – 6.0 mA – 20 5.5 VS = 12V 18 5.0 16 4.5 VS = 7.5V 14 4.0 OUTPUT VOLTAGE SWING TOTAL SUPPLY CURRENT 12 3.5 3.0 10 10 100 1k 10k –60 –40 –20 0 20 40 60 80 100 LOAD RESISTANCE – TEMPERATURE – C
TPC 2. Output Voltage Swing vs. Load Resistance TPC 5. Total Supply Current vs. Temperature
25 3 TA = 25 C SWING VS = 7.5V (NO LOAD) 20 A V p-p 2 –I SWING B 15 (RL = 150 ) 1 +IB 10 INPUT BIAS CURRENT 0 5 OUTPUT VOLTAGE SWING 0 –1 2 3 4 5 6 7 8 9 10 11 12 13 –60 –40 –20 0 20 40 60 80 100 SUPPLY VOLTAGE – Volts TEMPERATURE – C
TPC 3. Output Voltage Swing vs. Supply Voltage TPC 6. Input Bias Current vs. Temperature –4– REV. C
