Datasheet AD8023 (Analog Devices)
DescriptionHigh Current Output, Triple Video Amplifier
Pages / Page11 / 1 — High Current Output,. Triple Video Amplifier. AD8023. FEATURES. PIN …
RevisionA
File Format / SizePDF / 567 Kb
High Current Output,. Triple Video Amplifier. AD8023. FEATURES. PIN CONFIGURATION. Drives 13 V Output. 14-Lead SOIC
Datasheet AD8023 Analog Devices, Revision: A
a
High Current Output, Triple Video Amplifier AD8023 FEATURES PIN CONFIGURATION Drives 13 V Output 14-Lead SOIC Drives Unlimited Capacitive Load High Current Output Drive: 70 mA Excellent Video Specifications (R DISABLE 1 1 14 OUT 2 L = 150 ) Gain Flatness 0.1 dB to 10 MHz DISABLE 2 2 13 –IN 2 0.06% Differential Gain Error DISABLE 3 3 12 +IN 2 0.02 Differential Phase Error +VS 4 AD8023 11 –VS Power +IN 1 +IN 3 Operates on 2.5 V to 7.5 V Supply 5 10 10.0 mA/Amplifier Max Power Supply Current –IN 1 6 9 –IN 3 High Speed OUT 1 7 8 OUT 3 250 MHz Unity Gain Bandwidth (3 dB) 1200 V/ s Slew Rate Fast Settling Time of 35 ns (0.1%) High Speed Disable Function Turn-Off Time 30 ns
The AD8023 uses maximum supply current of 10.0 mA per
Easy to Use
amplifier and runs on ± 2.5 V to ± 7.5 V power supply. The
200 mA Short Circuit Current
outputs of each amplifier swing to within one volt of either
Output Swing to 1 V of Rails
supply rail to easily accommodate video signals. The AD8023 is unique among current feedback op amps by virtue of its large
capacitive load drive with a small series resistor, while still
LCD Displays
achieving rapid settling time. For instance, it can settle to 0.1% in
Video Line Driver
35 ns while driving 300 pF capacitance.
Broadcast and Professional Video
The bandwidth of 250 MHz along with a 1200 V/µs slew rate
Computer Video Plug-In Boards
make the AD8023 useful in high speed applications requiring
Consumer Video
a single +5 V or dual power supplies up to ± 7.5 V. Further-
RGB Amplifier in Component Systems
more, the AD8023 contains a high speed disable function for
PRODUCT DESCRIPTION
each amplifier in order to power down the amplifier or high The AD8023 is a high current output drive, high voltage output impedance the output. This can then be used in video multi- drive, triple video amplifier. Each amplifier has 70 mA of output plexing applications. The AD8023 is available in the indus- current and is optimized for driving large capacitive loads. The trial temperature range of –40°C to +85°C. amplifiers are current feedback amplifiers and feature gain flatness of 0.1 dB to 10 MHz while offering differential gain and phase error of 0.06% and 0.02°.
VIN VIN V V O O
Figure 1. Pulse Response Driving a Large Load Capacitor, Figure 2. Output Swing Voltage, C R L = 300 pF, G = +3, RF = 750 Ω, RS = 16.9 Ω, RL = 10 kΩ L = 150 Ω; VS = ±7.5 V, G = +10 REV. A Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties
which may result from its use. No license is granted by implication or
Tel: 781/329-4700 World Wide Web Site: http://www.analog.com
Fax: 781/326-8703 © Analog Devices, Inc., 2000
