15 /7 — AD815. 700. 1400. G = +10. 600. 1200. 500. 1000. SIDE B. SIDE A. G = +2. …
Revision
D
PDF / 527 Kb
AD815. 700. 1400. G = +10. 600. 1200. 500. 1000. SIDE B. SIDE A. G = +2. 400. 800. +TZ. 300. –TZ. (PER AMPLIFIER) 200. SINGLE-ENDED SLEW RATE – V. 100. 200
AD81570014005G = +10 ⍀ 600s1200s/ / 45001000SIDE BSIDE AG = +23400800+TZSIDE A3006002–TZ(PER AMPLIFIER) 200400SIDE B1SINGLE-ENDED SLEW RATE – V100200DIFFERENTIAL SLEW RATE – VOPEN-LOOP TRANSRESISTANCE – M0000510152025–40–20020406080100OUTPUT STEP SIZE – V p-pJUNCTION TEMPERATURE – ⴗ C Figure 22. Slew Rate vs. Output Step Size Figure 25. Open-Loop Transresistance vs. Temperature –8515VVS = ⴞ 15VS = ⴞ 15VSIDE B–8014RL = 150 ⍀ +PSRR+VSIDE AOUT| –V–7513OUT |+VOUTRL = 25 ⍀ PSRR – dB –7012SIDE AOUTPUT SWING – Volts| –VOUT |SIDE B–6511–PSRR–6010–40–20020406080100–40–20020406080100JUNCTION TEMPERATURE – ⴗ CJUNCTION TEMPERATURE – ⴗ C Figure 23. PSRR vs. Temperature Figure 26. Single-Ended Output Swing vs. Temperature –7427–7326–72VS = ⴞ 15V RL = 50 ⍀ –7125–VOUT–70+VOUTCMRR – dB24–69–CMRROUTPUT SWING – Volts–6823+CMRR–67–6622–40–20020406080100–40–20020406080100JUNCTION TEMPERATURE – ⴗ CJUNCTION TEMPERATURE – ⴗ C Figure 24. CMRR vs. Temperature Figure 27. Differential Output Swing vs. Temperature REV. D 7– Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION MAXIMUM POWER DISSIPATION Typical Performance Characteristics THEORY OF OPERATION Choice of Feedback and Gain Resistors PRINTED CIRCUIT BOARD LAYOUT CONSIDERATIONS POWER SUPPLY BYPASSING DC ERRORS AND NOISE POWER CONSIDERATIONS Other Power Considerations Parallel Operation Differential Operation Creating Differential Signals Direct Single-Ended-to-Differential Conversion Twelve Channel Video Distribution Amplifier OUTLINE DIMENSIONS Ordering Guide Revision History
