Datasheet OP467 (Analog Devices) - 10
Description | Quad Precision, High Speed Operational Amplifier |
Pages / Page | 20 / 10 — OP467. 500. S1 = ±15V. S = ±15V. A = 25°C. S2 = ±5V. 1252 × OP AMPS. L = … |
Revision | I |
File Format / Size | PDF / 493 Kb |
OP467. 500. S1 = ±15V. S = ±15V. A = 25°C. S2 = ±5V. 1252 × OP AMPS. L = 10kΩ. 400. CL = 50pF. VS1 = ±15V. 300. B d. –10. 200. VS2 = ±5V. –20. –30. 100. –40
OP467 50 500 V V S1 = ±15V S = ±15V 40 T V A = 25°C S2 = ±5V 1252 × OP AMPS R 30 L = 10kΩ 400 CL = 50pF 20 VS1 = ±15V ) 10 300 B d S ( 0 IT IN UN GA –10 200 VS2 = ±5V –20 –30 100
7 24
–40
0 02 2- 2- 30 30 00
–50 0
00
10k 100k 1M 10M 100M –100 –50 0 50 100 150 200 250 300 350 400 FREQUENCY (Hz) INPUT OFFSET VOLTAGE (V OS µV)
Figure 24. Noninverting Gain vs. Supply Voltage Figure 27. Input Offset Voltage Distribution
14 500 VS = ±15V VS = ±5V T T A = 25°C A = 25°C 12 1252 × OP AMPS 400 10 ) V POSITIVE G ( SWING 300 IN 8 S W IT S T UN U 6 200 TP NEGATIVE SWING OU 4 100 2
5 8 2 02 0 2- 2- 30 30
0
00
0
00
10 100 1k 10k –100 –50 0 50 100 150 200 250 300 350 400 LOAD RESISTANCE (Ω) INPUT OFFSET VOLTAGE (V OS µV)
Figure 25. Output Swing vs. Load Resistance Figure 28. Input Offset Voltage Distribution
5 500 VS = ±15V VS = ±15V TA = 25°C TA = 25°C 1252 × OP AMPS 4 400 POSITIVE ) SWING (V G 3 300 IN W S S IT T NEGATIVE U SWING UN 2 200 TP OU 1 100
6 9 2 02 0 2- 2- 30 30
0
00
0
00
10 100 1k 10k 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 LOAD RESISTANCE (Ω) TC VOS (µV/°C)
Figure 26. Output Swing vs. Load Resistance Figure 29. TC VOS Distribution Rev. * | Page 10 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS WAFER TEST LIMITS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE DICE CHARACTERISTICS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION OUTPUT SHORT-CIRCUIT PERFORMANCE UNUSED AMPLIFIERS PCB LAYOUT CONSIDERATIONS GROUNDING POWER SUPPLY CONSIDERATIONS SIGNAL CONSIDERATIONS PHASE REVERSAL SATURATION RECOVERY TIME HIGH SPEED INSTRUMENTATION AMPLIFIER 2 MHz BIQUAD BAND-PASS FILTER FAST I-TO-V CONVERTER OP467 SPICE MARCO-MODEL OUTLINE DIMENSIONS ORDERING GUIDE
