Datasheet AD810 (Analog Devices) - 7
DescriptionLow Power Video Op Amp with Disable
Pages / Page22 / 7 — Data Sheet. AD810. TYPICAL PERFORMANCE CHARACTERISTICS. ) V ± (. VS = …
File Format / SizePDF / 472 Kb
Data Sheet. AD810. TYPICAL PERFORMANCE CHARACTERISTICS. ) V ± (. VS = ±15V. OLTA. mA). T V. NO LOAD. S = ±5V. OU E. CURRE Y L. L = 150Ω. OF TH E
Data Sheet AD810 TYPICAL PERFORMANCE CHARACTERISTICS ) V ± ( VS = ±15V OLTA mA) T V NO LOAD S = ±5V OU E CURRE Y L L = 150Ω OF TH E
Data Sheet AD810 TYPICAL PERFORMANCE CHARACTERISTICS 20 10 ) V ± ( GE 9 15 VS = ±15V OLTA mA) 8 T V NO LOAD ( U NT V TP S = ±5V 10 7 OU E CURRE Y L R P L = 150Ω 6 OF TH E UP D 5 S ITU 5 GN A M 0 4 0 5 10 15 20
004
–60 –40 –20 0 20 40 60 80 100 120 140
007
SUPPLY VOLTAGE (±V)
1737-
JUNCTION TEMPERATURE (°C)
1737- Figure 6. Magnitude of the Output Voltage vs. Supply Voltage Figure 9. Supply Current vs. Junction Temperature
35 10 8 30 ) ±15V SUPPLY 6 V p) m 25 ( p- 4 V GE ( VS = ±5V 2 GE 20 OLTA 0 T V OLTA E 15 VS = ±15V T V –2 U TP 10 T OFFS –4 U OU P ±5V SUPPLY IN –6 5 –8 0 –10 10 100 1k 10k
005
008
LOAD RESISTANCE (Ω)
1737-
1737- Figure 7. Output Voltage vs. Load Resistance Figure 10. Input Offset Voltage vs. Junction Temperature
10 250 8 6 A) mA) 200 µ ( 4 ( NONINVERTING INPUT NT NT 2 VS = ±5V, ±15V VS = ±15V 0 CURRE 150 CURRE T AS –2 RCUI BI -CI UT INVERTING INPUT –4 VS = ±5V, ±15V RT INP 100 –6 HO S VS = ±5V –8 –10 50 –60 –40 –20 0 20 40 60 80 100 120 140
006
009
1737-
1737- Figure 8. Input Bias Current vs. Junction Temperature Figure 11. Short-Circuit Current vs. Junction Temperature Rev. B | Page 7 of 22 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION GENERAL DESIGN CONSIDERATIONS ACHIEVING VERY FLAT GAIN RESPONSE AT HIGH FREQUENCY CHOICE OF FEEDBACK RESISTOR PRINTED CIRCUIT BOARD LAYOUT QUALITY OF COAXIAL CABLE POWER SUPPLY BYPASSING POWER SUPPLY OPERATING RANGE OFFSET NULLING DISABLE MODE APPLICATIONS INFORMATION CAPACITIVE LOADS OPERATION AS A VIDEO LINE DRIVER 2:1 VIDEO MULTIPLEXER 4:1 MULTIPLEXER OUTLINE DIMENSIONS ORDERING GUIDE
