Datasheet AD795 (Analog Devices) - 6
DescriptionLow Power, Low Noise Precision FET Op Amp
Pages / Page20 / 6 — AD795. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 1.00. RL = 10kΩ. …
RevisionD
File Format / SizePDF / 440 Kb
AD795. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 1.00. RL = 10kΩ. 0.95. (±V E 15. A) 0.90 (p. +VIN. RANG. NT 0.85. DE O M 10. 0.80. CURRE
AD795 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 1.00 RL = 10kΩ 0.95 (±V E 15 A) 0.90 (p +VIN RANG NT 0.85 DE O M 10 0.80 CURRE
AD795 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 20 1.00 RL = 10kΩ ) 0.95 (±V E 15 A) 0.90 (p +VIN RANG NT 0.85 DE O M 10 0.80 N- CURRE O –VIN AS M 0.75 M BI UT CO P 5 0.70 UT IN P IN 0.65 0
4
0.60
7
0 5 10 15 20
00
0 5 10 15 20
00 45- 45-
SUPPLY VOLTAGE (±V) SUPPLY VOLTAGE (±V)
008 008 Figure 4. Common-Mode Voltage Range vs. Supply Voltage Figure 7. Input Bias Current vs. Supply Voltage
20 50 RL = 10kΩ SAMPLE SIZE = 1058 ) 40 (±V 15 E S T +VOUT UNI RANG F 30 E O E AG 10 T AG L O –VOUT NT 20 V UT RCE P E 5 P UT O 10 0
5
0
8
0 5 10 15 20
00
0 0.5 1.0 1.5 2.0
00 45- 45-
SUPPLY VOLTAGE (±V) INPUT BIAS CURRENT (pA)
008 008 Figure 5. Output Voltage Range vs. Supply Voltage Figure 8. Typical Distribution of Input Bias Current
30 10–9 VS = ±15V 25 p) 10–10 p- V ( (A) G 20 NT WIN E 10–11 S 15 GE CURR TA AS OL 10–12 BI V 10 T T U U P T INP 10–13 OU 5 0
6
10–14 10 100 1k 10k
00
–60 –40 –20 0 20 40 60 80 100 120 140
009 5- 5-
LOAD RESISTANCE (Ω)
84
TEMPERATURE (°C)
84 00 00 Figure 6. Output Voltage Swing vs. Load Resistance Figure 9. Input Bias Current vs. Temperature Rev. D | Page 6 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS MINIMIZING INPUT CURRENT CIRCUIT BOARD NOTES OFFSET NULLING AC RESPONSE WITH HIGH VALUE SOURCE AND FEEDBACK RESISTANCE OVERLOAD ISSUES INPUT PROTECTION PREAMPLIFIER APPLICATIONS MINIMIZING NOISE CONTRIBUTIONS USING A T NETWORK A pH PROBE BUFFER AMPLIFIER OUTLINE DIMENSIONS ORDERING GUIDE
