Datasheet AD829 (Analog Devices) - 3
DescriptionHigh Speed, Low Noise Video Op Amp
Pages / Page20 / 3 — Data Sheet. AD829. SPECIFICATIONS. Table 1. AD829JR. AD829AR. …
RevisionI
File Format / SizePDF / 381 Kb
Data Sheet. AD829. SPECIFICATIONS. Table 1. AD829JR. AD829AR. AD829AQ/AD829S. Parameter. Conditions. Min. Typ. Max Min. Max. Unit
Data Sheet AD829 SPECIFICATIONS Table 1 AD829JR AD829AR AD829AQ/AD829S Parameter Conditions Min Typ Max Min Max Unit
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
TA = 25°C and VS = ±15 V dc, unless otherwise noted.
Table 1. AD829JR AD829AR AD829AQ/AD829S Parameter Conditions VS Min Typ Max Min Typ Max Min Typ Max Unit
INPUT OFFSET VOLTAGE tMIN to tMAX ±5 V, 0.2 1 0.2 1 0.1 0.5 mV ±15 V 1 1 0.5 mV Offset Voltage Drift ±5 V, 0.3 0.3 0.3 µV/°C ±15 V INPUT BIAS CURRENT ±5 V, 3.3 7 3.3 7 3.3 7 µA ±15 V tMIN to tMAX 8.2 9.5 9.5 µA INPUT OFFSET CURRENT ±5 V, 50 500 50 500 50 500 nA ±15 V tMIN to tMAX 500 500 500 nA Offset Current Drift ± 5 V, 0.5 0.5 0.5 nA/°C ±15 V OPEN-LOOP GAIN VO = ±2.5 V, ±5 V 30 65 30 65 30 65 V/mV RL = 500 Ω RL = 150 Ω 40 40 40 V/mV tMIN to tMAX 20 20 20 V/mV VO = ±10 V, ±15 V 50 100 50 100 50 100 V/mV RL = 1 kΩ RL = 500 Ω 85 85 85 V/mV tMIN to tMAX 20 20 20 V/mV DYNAMIC PERFORMANCE Gain Bandwidth Product ±5 V 600 600 600 MHz ±15 V 750 750 750 MHz Full Power Bandwidth1, 2 VO = 2 V p-p, ±5 V 25 25 25 MHz RL = 500 Ω VO = 20 V p-p, ±15 V 3.6 3.6 3.6 MHz RL = 1 kΩ Slew Rate2 RL = 500 Ω ±5 V 150 150 150 V/µs RL = 1 kΩ ±15 V 230 230 230 V/µs Settling Time to 0.1% AV = –19 −2.5 V to ±5 V 65 65 65 ns +2.5 V 10 V step ±15 V 90 90 90 ns Phase Margin2 CL = 10 pF ±15 V RL = 1 kΩ 60 60 60 Degrees DIFFERENTIAL GAIN ERROR3 RL = 100 Ω, ±15 V 0.02 0.02 0.02 % CCOMP = 30 pF DIFFERENTIAL PHASE ERROR3 RL = 100 Ω, ±15 V 0.04 0.04 0.04 Degrees CCOMP = 30 pF COMMON-MODE REJECTION VCM = ±2.5 V ±5 V 100 120 100 120 100 120 dB VCM = ±12 V ±15 V 100 120 100 120 100 120 dB tMIN to tMAX 96 96 96 dB POWER SUPPLY REJECTION VS = ±4.5 V 98 120 98 120 98 120 dB to ±18 V tMIN to tMAX 94 94 94 dB INPUT VOLTAGE NOISE f = 1 kHz ±15 V 1.7 2 1.7 2 1.7 2 nV/√Hz INPUT CURRENT NOISE f = 1 kHz ±15 V 1.5 1.5 1.5 pA/√Hz Rev. I | Page 3 of 20 Document Outline Features General Description Connection Diagram Product Highlights Revision History Specifications Absolute Maximum Ratings Thermal Characteristics Metallization Photo ESD Caution Typical Performance Characteristics Test Circuits Theory of Operation Externally Compensating the AD829 Shunt Compensation Current Feedback Compensation Low Error Video Line Driver High Gain Video Bandwidth, 3-Op-Amp Instrumentation Amplifier Outline Dimensions Ordering Guide
