16 /7 — OP470. 130. TA = 25. 120. VS =. 15V. S =. A = +25. 110. 100. A = +125. TA …
Revision
B
PDF / 3.3 Mb
OP470. 130. TA = 25. 120. VS =. 15V. S =. A = +25. 110. 100. A = +125. TA = –55. Y CURRENT – mA. CMR – dB 60. L SUPPL. 10k. 100k. –75 –50. –25. 100 125
OP4701301010TA = 25C120VS =15VVTS =15VA = +25C91101008T8A = +125C90780706TA = –55C6Y CURRENT – mAY CURRENT – mACMR – dB 60550L SUPPLL SUPPL4044TATA30TOTO32010221101001k10k100k1M05101520–75 –50–250255075100 125FREQUENCY – HzSUPPLY VOLTAGE – VTEMPERSTURE –C TPC 10. CMR vs. Frequency TPC 11. Total Supply Current vs. TPC 12. Total Supply Current vs. Supply Voltage Supply Voltage 14014080130TTA = 25C130A = 25C120120VS = 15V601101101001009090408080–PSR707060PSR – dB 602050+PSR504040OPEN-LOOP GAIN – dB3030CLOSED-LOOP GAIN – dB02020101000–201101001k10k 100k 1M 10M 100M1101001k10k 100k 1M 10M 100M1k10k100k1M10MFREQUENCY – HzFREQUENCY – HzFREQUENCY – Hz TPC 13. PSR vs. Frequency TPC 14. Open-Loop Gain vs. Frequency TPC 15. Closed-Loop Gain vs. Frequency 25805000808TPHASETVA = 25CA = 25CS =15V20VRS =15V100L = 10kGBW400070615120V/mVGAIN3000ODUCT – MHz10140PHASE MARGIN= 586045160GAIN – dB2000WIDTH PR0180ANDPHASE SHIFT – Degrees502OPEN-LOOP GAIN – 1000PHASE MARGIN – Degrees–5200GAIN-B–102200400123456 7 8 9 100510152025–75 –50 –250255075 100 125 150FREQUENCY – MHzSUPPLY VOLTAGE – VTEMPERATURE –C TPC 16. Open-Loop Gain, Phase TPC 17. Open-Loop Gain vs. Supply TPC 18. Gain-Bandwidth Product, Shift vs. Frequency Voltage Phase Margin vs. Temperature REV. B –7– Document Outline FEATURES GENERAL DESCRIPTION PIN CONNECTIONS SIMPLIFIED SCHEMATIC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics APPLICATIONS INFORMATION Voltage and Current Noise TOTAL NOISE AND SOURCE RESISTANCE NOISE MEASUREMENTS— PEAK-TO-PEAK VOLTAGE NOISE NOISE MEASUREMENT—NOISE VOLTAGE DENSITY NOISE MEASUREMENT—CURRENT NOISE DENSITY CAPACITIVE LOAD DRIVING AND POWER SUPPLY CONSIDERATIONS UNITY-GAIN BUFFER APPLICATIONS 50k APPLICATIONS Low Noise Amplifier DIGITAL PANNING CONTROL SQUELCH AMPLIFIER FIVE-BAND LOW-NOISE STEREO GRAPHIC EQUALIZER OUTLINE DIMENSIONS Revision History
