Datasheet MBN52832 (Murata)
ManufacturerMurata
DescriptionBLE Module
Pages / Page34 / 1 — MBN52832 Data. Sheet. BLE Module. Revision History. Revision. Date. …
MBN52832 Data. Sheet. BLE Module. Revision History. Revision. Date. Author. Change Description. www.murata.com
Datasheet MBN52832 Murata
MBN52832 Data Sheet BLE Module Revision History Revision Date Author Change Description
0.1 06/03/2016 RF PD Preliminary version 0.2 06/16/2016 RF PD Modified the module block diagram. 0.3 8/25/2016 RF PD Update test data points 0.4 8/27/2016 RF PD Update module dimension and reference schematic 0.5 12/15/2016 RF PD Applied model/type name MBN52832 to the datasheet 0.6 02/01/2017 RF PD Update Table 2.1 and Figure 2.2 0.7 03/15/2017 RF PD Add sleep current 0.8 05/26/2017 RF PD Table 2.2 change pin 36, 37 pin 36 description to NC. Add section 6.1 and 6.2, recommendation for host PCB landing and placement. Updated reference schematic. Add section 9 and section 10, assembly and packaging information. Add section 12 Notice. Add section 13 Preconditions to use the module. 0.9 07/27/2017 RF PD Add regulatory section 0.92 8/23/2017 RF PD Update layout guidance for antenna connection; updated regulatory information 1.0 10/06/2017 Murata Update the max height to 0.9mm, remove the sample part number. 1.1 06/14/2018 Murata Remove Section 17, support contact. 1.2 10/10/2018 Murata Added FCC and IC certification update for portable application in section 11.6 1.3 11/13/18 Murata Corrected typos in section 7. 1.4 02/06/2020 Murata Corrected module height in figure 2.1 Reformatted the content of section 2.3 Add KC certificate information. Fig 10.7; table 11.1; add section 11.7 Copyright © Murata Manufacturing Co., Ltd. All rights reserved. October 2017 MBN52832 Data Sheet, v1.4, 02/06/2020
www.murata.com
Document Outline Revision History Table of Contents 1 Introduction 1.1 Features 1.2 Applications 1.3 Block Diagram 1.4 Acronyms 1.5 References 2 Mechanical Specification 2.1 Module Dimensions 2.2 Top and Side View 2.3 PCB Footprint Top View 2.4 Pin Configuration 3 DC Electrical Specification 3.1 Typical Power Consumption 4 RF Specification 5 Environmental Specification 5.1 Absolute Maximum Rating 5.2 Recommended Operating Condition 6 Power Sequence 7 Application Information 7.1 Recommended PCB Landing Pattern 7.2 Host PCB Layout Recommendations 7.3 Layout Guidance for Using Internal PCB Antenna 7.4 Layout Guidance for Microstrip Design And External Antenna 8 Application Reference 9 Assembly Information 10 Packaging and Marking Information 10.1 Dimensions of Tape (Plastic tape) 10.2 Dimensions of Reel 10.3 Taping Diagrams 10.4 Leader and Tail tape 10.5 Peeling Force 10.6 PACKAGE (Humidity proof Packaging) 10.7 Module Marking Information 10.8 Moisture Sensitivity Level 11 Regulatory Information 11.1 FCC Notice (USA) 11.2 FCC Labeling Requirements 11.3 IC Notice (Canada) 11.4 IC Labeling Requirements 11.5 ESTI compliance (Europe) 11.6 RF Exposure 11.6.1 Using on-board PCB antenna 11.6.2 Using external antenna 11.7 KC Certificate Notice 12 RoHS Information 13 Ordering Information 14 Notice 14.1 Storage Conditions 14.2 Handling Conditions 14.3 Standard PCB Design (Land Pattern and Dimensions) 14.4 Notice for Chip Placer 14.5 Operational Environment Conditions 14.6 Input Power Capacity 15 Preconditions To Use Murata Products
