Datasheet LTC3883, LTC3883-1 (Analog Devices) - 4
DescriptionSingle Phase Step-Down DC/DC Controller with Digital Power System Management
Pages / Page116 / 4 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
RevisionF
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC3883/LTC3883-1
VIN, SW .. –0.3V to 28V PGOOD, GPIO, SHARE_CLK, ITH, Topside Driver Voltage (BOOST) .. –0.3V to 34V VDD33, SYNC, WP ... –0.3V to 3.6V Switch Transient Voltage (SW) ... –5V to 28V INTVCC Peak Output Current ..100mA EXTVCC, INTVCC, BG, (BOOST – SW) ... –0.3V to 6V Operating Junction Temperature Range V + + – SENSE , ISENSE , ISENSE ... –0.3V to 6V (Note 2) .. –40°C to 125°C* RUN, SDA, SCL, ALERT ... –0.3V to 5.5V Storage Temperature Range .. –65°C to 150°C* FREQ_CFG, VOUT_CFG, VTRIM_CFG, *See Derating EEPROM Retention at Temperature in the ASEL, VDD25 .. –0.3V to 2.75V Applications Information Section for Junction Temperatures V – SENSE ... –0.3V to 0.3V in Excess of 125°C. (VIN_SNS – VIN), (VIN – IIN_SNS) .. –0.3V to 0.3V
PIN CONFIGURATION
LTC3883 LTC3883-1 TOP VIEW TOP VIEW – + – + V CC V CC TSNS V SENSE V SENSE I TH V IN INT BG PGND TSNS V SENSE V SENSE I TH V IN EXT BG PGND 32 31 30 29 28 27 26 25 32 31 30 29 28 27 26 25 VIN_SNS 1 24 BOOST VIN_SNS 1 24 BOOST IIN_SNS 2 23 TG IIN_SNS 2 23 TG I + + SENSE 3 22 SW ISENSE 3 22 SW I – – SENSE 4 33 21 VDD33 ISENSE 4 33 21 VDD33 SYNC 5 GND 20 SHARE_CLK SYNC 5 GND 20 SHARE_CLK SCL 6 19 WP SCL 6 19 WP SDA 7 18 VDD25 SDA 7 18 VDD25 ALERT 8 17 VTRIM_CFG ALERT 8 17 VTRIM_CFG 9 10 11 12 13 14 15 16 9 10 11 12 13 14 15 16 GPIO RUN DNC ASEL DNC GPIO RUN DNC ASEL DNC PGOOD PGOOD FREQ_CFG V OUT_CFG FREQ_CFG V OUT_CFG UH PACKAGE UH PACKAGE 32-LEAD (5mm × 5mm) PLASTIC QFN 32-LEAD (5mm × 5mm) PLASTIC QFN TJMAX = 125°C, θJA = 44°C/W, θJC = 7.3°C/W TJMAX = 125°C, θJA = 44°C/W, θJC = 7.3°C/W EXPOSED PAD (PIN 33) IS GND, MUST BE SOLDERED TO PCB EXPOSED PAD (PIN 33) IS GND, MUST BE SOLDERED TO PCB
LTC3883EUH#PBF LTC3883EUH#TRPBF 3883 32-Lead (5mm × 5mm) Plastic QFN –40°C to 105°C LTC3883IUH#PBF LTC3883IUH#TRPBF 3883 32-Lead (5mm × 5mm) Plastic QFN –40°C to 125°C LTC3883EUH-1#PBF LTC3883EUH-1#TRPBF 38831 32-Lead (5mm × 5mm) Plastic QFN –40°C to 105°C LTC3883IUH-1#PBF LTC3883IUH-1#TRPBF 38831 32-Lead (5mm × 5mm) Plastic QFN –40°C to 125°C Rev. F 4 For more information www.analog.com Document Outline Features Applications Typical Application Description Table of Contents Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Overview Main Control Loop EEPROM Power Up and Initialization Soft-Start Sequencing Voltage-Based Sequencing Shutdown Light Load Current Operation Switching Frequency and Phase Output Voltage Sensing Output Current Sensing Auto Calibration Accurate DCR Temperature Compensation Input Current Sensing Load Sharing External/Internal Temperature Sense RCONFIG (Resistor Configuration) Pins Fault Detection and Handling Internal Memory with CRC and ECC Serial Interface Communication Failure Device Addressing Responses to VOUT and IOUT Faults Output Overvoltage Fault Response Output Undervoltage Response Peak Output Overcurrent Fault Response Responses to Timing Faults Responses to VIN OV Faults Responses to OT/UT Faults Overtemperature Fault Response—Internal Overtemperature and Undertemperature Fault Response—Externals Responses To Input Overcurrent And Output Undercurrent Faults Responses to External Faults Fault Logging Bus Timeout Failure Similarity Between PMBus, SMBus and I2C 2-Wire Interface PMBus Serial Digital Interface PMBus Command Summary PMBus Commands *Data Format Applications Information Current Limit Programming ISENSE+ and ISENSE– Pins Low Value Resistor Current Sensing Inductor DCR Current Sensing Slope Compensation and Inductor Peak Current Inductor Value Calculation Inductor Core Selection Power MOSFET and Schottky Diode (Optional) Selection Variable Delay Time, Soft-Start and Output Voltage Ramping Digital Servo Mode Soft Off (Sequenced Off) INTVCC Regulator Topside MOSFET Driver Supply (CB, DB) Undervoltage Lockout CIN and COUT Selection Fault Conditions Open-Drain Pins Phase-Locked Loop and Frequency Synchronization Minimum On-Time Considerations Input Current Sense Amplifier RCONFIG (External Resistor Configuration Pins) Voltage Selection Frequency and Phase Selection Using RCONFIG Address Selection Using RCONFIG Efficiency Considerations Checking Transient Response PolyPhase Configuration PC Board Layout Checklist PC Board Layout Debugging Design Example Connecting the USB to I2C/SMBus/PMBus Controller to the LTC3883 In System Inductor DCR Auto Calibration Accurate DCR Temperature Compensation LTpowerPlay: An Interactive GUI for Digital Power PMBus Communication and Command Processing PMBus Command Details Addressing and Write Protect General Configuration COMMANDS On/Off/Margin PWM Configuration Voltage Input Voltage and Limits Output Voltage and Limits Current Output Current Calibration Output Current Input Current Calibration Input Current Temperature External Temperature Calibration External Temperature Limits Timing Timing—On Sequence/Ramp Timing—Off Sequence/Ramp Precondition for Restart Fault Response Fault Responses All Faults Fault Responses Input Voltage Fault Responses Output Voltage Fault Responses Output Current Fault Responses IC Temperature Fault Responses External Temperature Fault Sharing Fault Sharing Propagation Fault Sharing Response Scratchpad Identification Telemetry NVM Memory Commands Store/Restore Fault Logging Block Memory Write/Read Typical Applications Package Description Revision History Typical Application Related Parts
