Datasheet MAX4400, MAX4401, MAX4402, MAX4403 (Maxim) - 6
ManufacturerMaxim
DescriptionSingle/Dual/Quad, Low-Cost, Single-Supply, Rail-to-Rail Op Amps with Shutdown
Pages / Page13 / 6 — Electrical Characteristics. TA = -40°C to +125°C. PARAMETER. SYMBOL. …
Electrical Characteristics. TA = -40°C to +125°C. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. Note 1:. Note 2:. Note 3:
Electrical Characteristics TA = -40°C to +125°C PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Note 1: Note 2: Note 3:
MAX4400–MAX4403 Single/Dual/Quad, Low-Cost, Single-Supply, Rail-to-Rail Op Amps with Shutdown
(VDD = +5V, VSS = 0V, VCM = 0V, VOUT = VDD/2, RL = ∞ connected to VDD/2,
, unless otherwise noted.) (Note 3)
Supply Voltage Range VDD Inferred by PSRR test 2.5 5.5 V 800 Supply Current per Amplifier IDD µA MAX4400/MAX4401 ±6.5 Input Offset Voltage VOS MAX4402/MAX4403 ±8.0 mV Input Offset Voltage Drift TCVOS ±1 μV/°C Input Bias Current IB (Note 2) ±100 pA Input Offset Current IOS (Note 2) ±100 pA Input Common-Mode Voltage Range VCM Inferred from CMRR test VSS VDD - 1.5 V V Common-Mode Rejection Ratio CMRR SS ≤ VCM ≤ VDD - 1.5V 65 dB VSS ≤ VCM ≤ VDD - 1.0V TA = -20°C to +125°C 50 Power-Supply Rejection Ratio PSRR 2.5V ≤ VCC ≤ 5.5V 74 dB Device in shutdown T Shutdown Mode Output mode, SHDN = V A = -40°C to +85°C ±1.0 SS, Leakage IOUTSHDN V μA SS < VOUT < VDD (Note 1) TA = +85°C to +125°C ±5.0 SHDN Logic-Low VIL (Note 1) 0.3 × VDD V SHDN Logic-High VIH (Note 1) 0.7 × VDD V SHDN Input Current IIL, IIH SHDN = VDD or VSS (Notes 1, 2) ±1000 nA Large-Signal Voltage Gain AVOL VSS + 0.3V ≤ VOUT ≤ VDD - 0.3V, RL = 2kΩ 85 dB Output Voltage High VOH Specified as |VDD - VOH|, RL = 2kΩ 250 mV Output Voltage Low VOL Specified as |VSS - VOL|, RL = 2kΩ 100 mV
Note 1:
Shutdown mode is only available in the 6-pin SC70 single op amp (MAX4401).
Note 2:
Guaranteed by design.
Note 3:
Specifications are 100% tested at TA = +25°C (exceptions noted). All temperature limits are guaranteed by design. www.maximintegrated.com Maxim Integrated │ 6
