Datasheet MAX4400, MAX4401, MAX4402, MAX4403 (Maxim) - 8
ManufacturerMaxim
DescriptionSingle/Dual/Quad, Low-Cost, Single-Supply, Rail-to-Rail Op Amps with Shutdown
Pages / Page13 / 8 — Typical Operating Characteristics (continued). OUTPUT VOLTAGE SWING LOW. …
Typical Operating Characteristics (continued). OUTPUT VOLTAGE SWING LOW. COMMON-MODE REJECTION RATIO. LARGE-SIGNAL GAIN
Typical Operating Characteristics (continued) OUTPUT VOLTAGE SWING LOW COMMON-MODE REJECTION RATIO LARGE-SIGNAL GAIN
MAX4400–MAX4403 Single/Dual/Quad, Low-Cost, Single-Supply, Rail-to-Rail Op Amps with Shutdown
(VDD = +5V, VSS = 0V, VCM = VDD/2, VSHDN = 5V, RL = ∞ connected to VDD/2, TA = +25°C, unless otherwise noted.)
OUTPUT VOLTAGE SWING LOW COMMON-MODE REJECTION RATIO LARGE-SIGNAL GAIN vs. TEMPERATURE vs. TEMPERATURE vs. OUTPUT VOLTAGE
50 -60 140 RL = 2kΩ to VDD/2 RL = 2kΩ 120 MAX4400 toc10 MAX4400 toc11 MAX4400 toc12 40 -70 100 30 (mV) 80 EE -80 - V CMRR (dB) GAIN (dB) 60 20 V OL 40 -90 10 20 0 -100 0 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 120 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 TEMPERATURE (°C) TEMPERATURE (°C) VOUT (V)
LARGE-SIGNAL GAIN MINIMUM OPERATING VOLTAGE TOTAL HARMONIC DISTORTION vs. TEMPERATURE vs. TEMPERATURE vs. FREQUENCY
140 3.0 0.1 RL = 2kΩ RL = 2kΩ 135 VOUT = 2VP-P MAX4400 toc13 MAX4400 toc14 A MAX4400 toc15 V = +1 130 2.5 0.01 125 (V) 120 2.0 V MIN THD (%) GAIN (dB) 115 0.001 110 1.5 105 100 1.0 0.0001 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 120 10 100 1k 10k 100k TEMPERATURE (°C) TEMPERATURE (°C) FREQUENCY (Hz)
TOTAL HARMONIC DISTORTION TOTAL HARMONIC DISTORTION TOTAL HARMONIC DISTORTION vs. FREQUENCY PLUS NOISE vs. INPUT AMPLITUDE PLUS NOISE vs. INPUT AMPLITUDE
0.01 10 10 RL = 100kΩ RL = 2kΩ RL = 100kΩ VOUT = 2VP-P f = 10kHz f = 10kHz A MAX4400 toc16 V = +1 1 BW = 20kHz MAX4400 toc17 1 BW = 20kHz MAX4400 toc18 0.1 0.1 0.001 THD (%) THD + N (%) 0.01 THD + N (%) 0.01 0.001 0.001 0.0001 0.0001 0.0001 10 100 1k 10k 100k 0 0.5 1.0 1.5 2.0 2.5 3.0 0 0.5 1.0 1.5 2.0 2.5 3.0 FREQUENCY (Hz) VIN (VP-P) VIN (VP-P) www.maximintegrated.com Maxim Integrated │ 8
